intake manafold stuck open?
Old Sep 21, 2010 | 12:30 PM
kamakazi1's Avatar
my check engin light came on and the diagnostic said the intake manafold is stuck open. I dont have the $ to bring it to the dealership any suggestions?
Old Sep 21, 2010 | 12:45 PM
My crystal ball was revoked along with the other members ones!
What year truck?
What motor size?
What dtc codes?
We'll help you solve your issue if you can post up that info..........
Veteran: Army
how about you post the codes, make, model, engine, mechanical background and tools if you own any
Old Sep 21, 2010 | 01:10 PM
What they said.
Old Sep 21, 2010 | 01:19 PM
kamakazi1's Avatar
Sorry guys my bad. 2005 FX4 5.4 Liter V8. I left the dtc code at my house I'll get you that later.
Old Sep 21, 2010 | 04:32 PM
Do you by chance have an aftermarket intake?
Old Sep 22, 2010 | 08:11 AM
kamakazi1's Avatar
No I dont have an aftermarket intake. The troubleshoooting code was P2004. The Definition for this is: Intake manifold runner control (IMRC) stuck open;
Explanation: has commanded the IMRC closed but detects it open
Probable cause: Short circuit condition, damaged IMRC actuator or solenoid, blocked vacuum hoses.
The truck is still running fine and I wiped the code and changed fuses but the check engine light still comes on. Any suggestions?
Old Sep 22, 2010 | 08:16 AM
MGDfan's Avatar
If funds are tight right now, You can run it like that until the cows come home - will do no damage. May lose a bit of power down low ( the IMRC is designed to enhance intake charge velocity - ergo, torque - at low speeds).
May not even notice: https://www.f150online.com/forums/4011545-post2.html
Better than having the 'stuck shut' code
To get at the IMRC & related components, some top-end disassembly is required - so the labour rate alone is gonna hurt (unless you can do the teardown yerself). Could not find the parts on RockAuto - no idea of cost.
BTW on a 5.4 3V it is also referred to as CMCV (Charge Motion Control Valves)... fyi in case you need to find more info ...
MGD
Old Sep 22, 2010 | 08:50 AM
MGD
The tsb that the other member posted in the link you provided is interesting.......
Under service proceedure step #1
"Recalibrate with sludge compensation strategy"
Lazy bums! Ford would rather do a reflash than clean!
JMHO
Old Sep 22, 2010 | 08:57 AM
MGDfan's Avatar
JMHO
Dang 'puters is takin' over everythang!
Too bad they don't have a Hemi compensation strategy, lol
MGD
Old Sep 22, 2010 | 11:31 AM
kamakazi1's Avatar
Should this affect my fuel economy? I'm only getting about 13 mpg or even less at times. Is this normal or should i be getting better?
Old Sep 22, 2010 | 11:56 AM
MGDfan's Avatar
Yes - it might - part of the premise behind this complexity is enhancing efficiency in the various operation regimes - part-throttle light load, WFO, etc ...
I said it would not hurt (the truck) but it wil not help (yer mileage). Get it addressed as soon as you are able.
MGD
Old Sep 22, 2010 | 12:25 PM
kamakazi1's Avatar
thanks
Old Oct 26, 2010 | 12:23 PM
kamakazi1's Avatar
I've been told the only way to really increase my fuel econemy is to put a chip in my truck. Do you have any suggestions as to a good affordable chip?
Old Oct 26, 2010 | 07:34 PM
avfrog's Avatar
^ Still not really going to make a significant difference.
