thinking about having a Magnaflow muffler installed
Old Jul 17, 2010 | 10:55 AM
chiaronate's Avatar
I have been thinking about having a Magnaflow muffler installed without a cat-back kit, just the muffler..would the correct size be 2.5 inches on this thing? The reason I would like to do this is to have a little more hp/tq for less downshifting out of overdrive going up hills, and the added sound would be ok too. I was thinking a 22 inch muffler because I would like it to be relatively quiet, something like a factory 2004 muffler sounds maybe. The guy I talked to at Sears said it wouldn't help at all with downshifting and I would probably lose gas mileage, is he correct about that? I also mentioned putting on a cold air intake and he said that wouldn't help either. I already placed an order on a cold air intake, and am planning on having a muffler installed soon. Any info. on this would be greatly appreciated.
Old Jul 17, 2010 | 11:46 AM
4.6 Punisher's Avatar
The Sears guy is right, except for the mileage part. You're not going to gain anything noticeable with just a muffler swap and a cold air intake, especially without a tune.
Old Jul 17, 2010 | 12:04 PM
chiaronate's Avatar
Ok thanks, I guess I'll have a Magnaflow put on just for the sound then..is the 22 inch similar in volume to the 2004-2008 factory muffler? I found an audio clip on here with the same muffler-only install on a similar year as mine, but I can't really tell from it.
Old Jul 17, 2010 | 01:06 PM
It will be extremely quiet, possibly too quiet. I would suggest an 18" oval body. The 4 cat system is what will keep the 18" tame enough.
Old Jul 17, 2010 | 01:31 PM
chiaronate's Avatar
More quiet than the factory 2004-2008 muffler? I like the sound level of that one.
Old Jul 17, 2010 | 01:37 PM
The 22" might be as quiet as the 2004-2005 trucks but with that Magnaflow tone. The late 2005's-2008's only have 2 cats, so they sound slightly louder.
Old Jul 17, 2010 | 02:09 PM
MRLSU2U's Avatar
Do a 14"!!!!
Old Jul 17, 2010 | 02:29 PM
Fordahaulic's Avatar
Getting the truck to breath better is a good start. So a CAI and a free-flowing exhaust will get things going. A good tuner however, will get you better results like 4.6 said. Since you're having issues with the trans shifting into O/D, I assume your either towing something, or have oversized rubber. In that case a tuner with a tow tune as one of your options would definitely help there. That being said, your 4 cats are the biggest problem. I had a quad cat set-up before and replacing them with 2 high flows made a big difference for my truck. Keep in mind that doing so will have an increase in the db department.
Old Jul 17, 2010 | 02:33 PM
chiaronate's Avatar
That would be great for me, I don't want anything too much louder..got that out of my system with Flowmasters on the Mustangs I used to have.
Old Jul 17, 2010 | 02:36 PM
chiaronate's Avatar
I don't do any towing and I have very close to factory diameter tires, I have the downshifting when the hills get steep is all. Are you saying if I take two of the catalytic converters off the exhaust would flow much better, or would that just be for sound?
Old Jul 17, 2010 | 03:02 PM
Your quad cat system is highly restrictive, swapping them with two high-flows will yield much better CFM numbers, and will accordingly give you better performance and throttle response......better sound in my opinion also, but will be louder. A larger diameter oval muffler should keep things on the quieter side.
Old Jul 17, 2010 | 03:04 PM
Oh sorry, not just 2 of your cats....swap all four for two high-flows.
Old Jul 17, 2010 | 03:32 PM
A programmer would be better for performance if that's your main goal. If you can get all of it done (muffler, CAI, cats, programmer), then it will perform much better. Hi-flow cats will make it louder and more aggressive.
Old Jul 17, 2010 | 03:43 PM
chiaronate's Avatar
Ok how does that work, do I buy that as a kit with the pipes included, or just install two converters into the original pipes?
Old Jul 17, 2010 | 03:47 PM
chiaronate's Avatar
I used to have a programmer with one of my Mustangs, manual transmission..didn't notice anything at all with that. I was thinking a programmer would help with shift firmness, but that's probably it..I'm not planning on modding so much that I would really benefit from a custom tune.
