hi flow cats
Old Jul 1, 2010 | 06:32 PM
Hiwire's Avatar
hi flow cats
If your only option was to retain the stock Y instead of going to true duals, but you were able to swap out cats, would it be beneficial to replace all 4 cats with high flow cats on a 2000 5.4. Looking for a way to open up as much as I can while still retaining the 4 cats and stock Y.
Old Jul 1, 2010 | 06:37 PM
Cut the rears out and replace the fronts with highflows.
Old Jul 1, 2010 | 06:43 PM
Hiwire's Avatar
Going to have to retain 4 cats.
Old Jul 1, 2010 | 06:46 PM
4.6 Punisher's Avatar
X2
Or just remove the rear cats and leave the fronts. Just as good as hi-flows, but there is a chance that you will through a CEL.
Old Jul 1, 2010 | 07:14 PM
southern2003fx4's Avatar
wats X2 mean? an CEL?
Old Jul 1, 2010 | 07:17 PM
Hiwire's Avatar
Here in NY throwing a CEL is not a good thing. I need to avoid that. I finally found someone that will replace cats with highflow versions even though they wont delete them. Im just wondering if there are highflow replacements for both types of cats or only fronts
Old Jul 1, 2010 | 07:29 PM
naw i was guna get all highflows from magnaflow but it was guna run 1200 parts only because u have 2 get the front 2 seperaate from the rear 2 very expensive
Old Jul 1, 2010 | 08:15 PM
If you have to have 4 cats because of a visual inspection, replace the rear cats with hi-flows. The front cats are more like resonators than cats.
And "X2" means that I agree with the person I quoted.
Ex.
I like boobies
X2
Old Jul 1, 2010 | 08:26 PM
Hiwire's Avatar
Thanks 4.6 Thats pretty much the info I was looking for.
and on the boobies issue...X3
Old Jul 1, 2010 | 10:49 PM
avfrog's Avatar
You don't "have" to have the stock y pipe though... x4 on boobies
Old Jul 1, 2010 | 11:30 PM
X5 on boobies!
Old Jul 2, 2010 | 06:04 AM
Hiwire's Avatar
I have yet to find a muffler shop that will reconfigure that Y pipe here. They will replace cats but none of them will eliminate cats or eliminate the Y pipe. If there is anyone on here within a reasonable drive if me Id be willing to take a drive to get it done but otherwise I think my best option here in NY is to just go with the shorties, replace the rear cats, and run straight pipes or a bullet with a Y.
Old Jul 2, 2010 | 11:33 AM
jtwoodall's Avatar
I had the exact same problem, the big name muffler shops always said no, especially over the phone. Go to a local shop and talk to the mechanic in person and offer to pay in cash. I was quoted $240 to remove all 4 and replace with 2 94106's. Let him keep the stock cats and knocked the price down to $180. Paid in cash, no receipt, Im pretty sure that transaction stayed off the books. Just talk to them in person at a local shop and you should be good to go. I have the y-pipe, 2 hi-flow cats on my '00 4.6 and it sounds amazing.
Old Jul 2, 2010 | 11:51 AM
jump n's Avatar
x6
I'm hoping to do some high flows too. I want some more sound out of mine. Kinda bored with what I have.
Old Jul 2, 2010 | 12:10 PM
2low2slow's Avatar
Sounds like you're from California. I made a thread about taking someone telling my my true dual set up was illegal, but not all exhaust shops are the same. Some are more strict than others.
