Si/DO or True Duals
Si/DO or True Duals
Either way im probably going to run the same muffler, either as a SI/DO or SI/SO. Is there any benfits from going from one exhaust or anyothere. Gains from True Duals. Basically tell me why you think I should go Si/Do or True Duals.
I love me the sound of a loud SISO under full throttle, sounds so clean & mean
The true duals aren't putting out much more hp then sido unless you get one of them fancy dancy X-Pipes and junk.
true dual benefits over SI/SO & SI/DO" high end rpm power, highway economy, rumble, bragging rights.
cons: low end torque loss when done improperly without crossover or proper sizing/bending, 40% more in costs.
I don't know the pro and cons of each but if all you need is an X pipe to gain more from duals than single they can be bought for around $40. I am personally going with true duals, have always heard good thing about them. I am sure someone else will chime in that knows more about it.
2.25" pipes for low end torque, 2.5" for top end. In some cases, the cost for true duals comes out to be the same as a premade cat-back.
Another guy for true duals here. No power loss issues or anything, and I even got one of those "fancy dancy X-Pipes and junk" put on.
http://www.youtube.com/watch?v=Eq9yNA30pY8
http://www.youtube.com/watch?v=drWZ6ZTcf0M
http://www.youtube.com/watch?v=GA8gci7Obqo
- NCSU
- NCSU
