Magnapack help!
Old May 22, 2010 | 03:19 PM
jro08's Avatar
Magnapack help!
Hey guys
I was wondering if I can run a 3" magnapack jus by itself dumPed out?
I would like to do it to my 06 5.4L. If I can. Any advice or input would be appreciated.
Old May 22, 2010 | 08:05 PM
You certainly can. All you will need to do is get a hanger mounted on, or before the muffler.
Old May 22, 2010 | 08:56 PM
avfrog's Avatar
Noisy inside! But... I have a feeling that you will like it!
Old May 23, 2010 | 01:15 AM
jro08's Avatar
Alright!!!! Do I need to put a tip on to aim down or jus leave it?
Thanks guys this jus made my day
Old May 23, 2010 | 01:52 AM
You can just put a curve down dump on it, leaving it open would sound a little better, or going with the shortest dump possible. Adding a cheapo chromed tip will help it echo outside better.
Old May 23, 2010 | 12:47 PM
avfrog's Avatar
Tip or NO turn down at all!
Old May 23, 2010 | 01:20 PM
jro08's Avatar
If I have no turn down at all will it sound jus as good as puttin tips on?
Old May 23, 2010 | 03:40 PM
Just about. Just be sure the outlet is past the cab or its an inspection fail. The purpose of the turndowns is to guide it behind the cab and angle the fumes down. They cut down the decibels a little while doing this though.
Old May 23, 2010 | 07:51 PM
avfrog's Avatar
It will probably sound about the same, maybe a hair quieter with pipe and a tip behind it.
Old May 23, 2010 | 10:24 PM
jro08's Avatar
Ya I'm gonna try it without the tip first..I ordered it today so now jus have to look in to some hi flow cats!!!!
Old May 23, 2010 | 11:09 PM
part #94106 from PerformancePeddler.com, coupon code 'clubgp'.
Old May 24, 2010 | 12:26 AM
jro08's Avatar
Sweet thanks I will order them this week also!!!!!! I jus need two right? Will I Need to move o2 behind the hiflows?
