will cutting off the cats
Old May 19, 2010 | 01:59 PM
whitaker83's Avatar
will cutting off the 4 cats on a 04 f150 5.4 effect anything
Old May 19, 2010 | 02:04 PM
06hdfxst's Avatar
Why not just take them out and replace them with high flow cats?
Old May 19, 2010 | 02:26 PM
f150fella08's Avatar
failed inspections/emissions testing possible fine/impound of your truck
cut the rear converters off, they arent monitored, that or cut all 4 off and replace the front ones, the ones that ARE monitored with magnaflow converters
you will get a CEL if you cut the converters off without a tune and probably wont run right
Old May 19, 2010 | 02:28 PM
whitaker83's Avatar
cheaper to just cut em off i took them off on my 98 f150 without any problems i was just wondering if a 04 f150 would be the same
Old May 19, 2010 | 02:31 PM
why do you want to cut them off?? if your looking to louden up an aftermarket system just remove the rear ones yourself
Old May 19, 2010 | 05:27 PM
Remove the rears. Stay legal that way, and still possible to pass a sniffer test if fully warm. $30 in supplies, $50 or so if you buy stainless piping with clamps.
Old May 19, 2010 | 10:43 PM
avfrog's Avatar
Not if you tune or do the "gotts" mod on the o2 sensors. No kitty for me!
Old May 22, 2010 | 04:23 PM
00grn5.4's Avatar
darren, are you saying that theres a possibility that one may pass the sniffer even with the back 2 out??
ive been wanting to do this for so long now but i dont want to fail inspection and cant afford hi flows right now.
Old May 22, 2010 | 08:02 PM
Technically yes, I cant prove this, but a bud of mine with a 2002 chopped all his cats out and cleaned them out, ran pipe through the rear cats and left the pre-cats open without feeding pipe, and runs a SI/DO Magnaflow system and claimed he passed the emissions sniffer. He said he made all his errands and a couple WOT pulls, and went to get it checked out and it burned clean enough to pass the sniffer.
These engines are much cleaner burning than the older ones so I can believe some of it. So if thats the case, I can definitely see my truck passing a sniffer test if fully warm 190+ degrees. My exhaust smells a bit cat-less on cold starts, but otherwise it never smells bad when warm.
Old May 24, 2010 | 11:20 AM
00grn5.4's Avatar
dang.. well its kinda sketchy though. idk if i wanna risk it. lol
those back ones may be coming out next week though anyways. ill be out of school and ill have lots of time
i know you can clamp the new pipe on.. but it really doesnt seem like theres much room to clamp.
