Air Intake Systems
Old Apr 26, 2010 | 12:03 PM
L-Train04's Avatar
Air Intake Systems
I'm looking to air a Air Intake System to my 2004 F150 Lariat which is the best out there? I was consitering a S&B, anyone running one of these?
Old Apr 26, 2010 | 12:10 PM
MGDfan's Avatar
Hello & Welcome!
Good choice. Probably the best of the lot since the demise of AirForce One (the company, not the plane )
Steer clear of the Sphincter (a.k.a. Spectre) CAI, and anything with a Volant name on it. Total junk.
Also - please be aware that yer '04 may have a pre-existing lean tendency - which will be exacerbated by an aftermarket CAI. Will likely need tuning to alleviate safely.
Consider the intake mod here: https://www.f150online.com/forums/ar...04-2008-a.html
Cheap & effective - and Safe.
Good luck sir.
MGD v5.0
Old Apr 26, 2010 | 12:11 PM
If you have the 5.4, you will need custom tuning to be sure you are not running lean on a 2004. You might be ok, maybe not, but you need custom tuning anyway to take full advantage of the CAI.
Old Apr 26, 2010 | 12:39 PM
L-Train04's Avatar
is the custom tuning somethign that I can do? or do I need to take it in for that? If so what does it usually run?
Old Apr 26, 2010 | 12:47 PM
You need to read this and then spend some time reading in the Chips and Tuner forum.
https://www.f150online.com/forums/ch...unes-read.html
Old Apr 26, 2010 | 12:59 PM
shotgunz's Avatar
Old Apr 26, 2010 | 01:22 PM
MGDfan's Avatar
Originally Posted by shotgunz
Where were you when I needed you???
I could have used that Here
OP - don't mind him - he's harmless (mostly) lol.
MGD v5.0
