will a throttle body spacer help?
Old Apr 6, 2010 | 11:36 AM
2wd98f150's Avatar
i'm looking at improving my performance and i came across a throttle body spacer. It looks like a good deal if it does what it says it does but does it really do all of that? increasing hp, torque, and fuel economy? I have a 98 f150 with a 4.6l.
if anyone else has used one of these spacers please let me know how it has worked out for you
Old Apr 6, 2010 | 11:40 AM
ChrisAU's Avatar
No.
It's a paper weight.
FATHERFORD's Avatar
I personally gained over 200rwhp and nearly 300ftlbs with my throttle body spacer. I saw a slight decrease in MPG though.
Old Apr 6, 2010 | 11:44 AM
MGDfan's Avatar
Me too! And, when I combined that with an IAT resistor, a tornado, a new muffler tip and some stickers, I also lost 40 pounds, tossed my Viagra and Ginseng, and quit drinking!
OP - honestly - with 159 posts, you have not yet figured out how to use this: https://www.f150online.com/forums/search.php ... to find tons of these: https://www.f150online.com/forums/19...?highlight=tbs... ?
Jeez....you related to that Shotgunz feller?
MGD v5.0
Old Apr 6, 2010 | 11:48 AM
4.6 Punisher's Avatar
Buy it now, listen to no else but us three!
Old Apr 6, 2010 | 12:20 PM
shotgunz's Avatar
Talking
MGD v5.0
So how do you play pool with a rope?
Now I understand his issues; MGDfan hasn't had a drink or been laid since V2.1e (02-22-2010, 01:36 PM, https://www.f150online.com/forums/4103288-post2.html)
hehe
Old Apr 6, 2010 | 12:41 PM
FlashmasterK's Avatar
Just put a number 8 sticker on the side of the truck. As good a dual turbo
Old Apr 6, 2010 | 12:42 PM
TBA= total bull *****
Old Apr 6, 2010 | 12:43 PM
thejake1989's Avatar
itll help you intake sound louder thats about it.
Old Apr 6, 2010 | 12:46 PM
Oh thats nice, auto edit
becomes ****
Last edited by Bluejay; Apr 6, 2010 at 01:15 PM. Reason: Do not circumvent the language filter, it is there for a reason
Old Apr 7, 2010 | 02:08 AM
sparko2010's Avatar
Of course it helps.... make your truck whistle like an import.
Throttle body spacers are completely useless (except on old GM TBI setups). The logic behind them is completely flawed. A spacer only helps if the fuel is introduced into the intake manifold from the same point that air enters (like a carb setup). A better designed manifold is a better solution for that though. Basically, a throttle body spacer is not going to change the way that air or fuel enters the combustion chamber because its before the injectors and any "spiral flow" there supposedly is, is quickly disrupted when it splits off abruptly in 8 directions. No change = no power increase.
Old Apr 7, 2010 | 09:41 PM
BlackFord123's Avatar
i got one:o i like it
no gain in power though...
Old Apr 7, 2010 | 09:44 PM
wutecht's Avatar
$125 paper weight. you can get more power if you paint flames on the truck and go to ebay and look up turbo whistle and put one in your exhaust pipe
Old Apr 7, 2010 | 10:45 PM
dilloncawthon's Avatar
negative ghostrider
Old Apr 8, 2010 | 08:49 AM
^^^ the pattern is full
