What xpipe?
Old Mar 26, 2010 | 02:01 PM
forwheelin49's Avatar
What xpipe?
So where an what xpipe are you guys buying when running your true dual setups for the best performance. Are you guys running the 2.25 or 2.5? Right now i just have a cheap flopro si/so dumped.I really want more performance than sound!
Old Mar 26, 2010 | 02:05 PM
Run an X pipe whatever size your system as is. Do not run a 2.25" X pipe on a 2.5" system for example.
Old Mar 26, 2010 | 02:51 PM
haha definatly would not run a 2.25 on a 2.5 system, I guess its the 4.6 guys that have been using the 2.25 , Darren where did you order your xpipe from and what brand?
Old Mar 26, 2010 | 03:06 PM
ChrisAU's Avatar
Well when people get their true duals run a lot of people size down to 2.25" to retain back pressure, mine were done that way when I had them.
Old Mar 26, 2010 | 03:49 PM
grizzstang's Avatar
Mine are stock size 2.5" and they are fine but if I was to do it again I would do them as ChrisAU suggested.
My X-pipe was made by the exhaust shop. Magaflow makes a nice one if you prefer something premade.
You want to install the X-pipe as close to the engine as possible.
Old Mar 26, 2010 | 05:14 PM
When you say as close to the engine as possible do you mean even before the cats or do you mean where the pipes Y at?
Old Mar 26, 2010 | 05:57 PM
Ricky Bobby FX4's Avatar
you want to install it were the factory Y-pipe used to be
Old Mar 26, 2010 | 06:23 PM
avfrog's Avatar
Yes, but not to retain back pressure. 2.25" with an X = max velocity and max exhaust scavenging for the best low RPM torque curve.
Old Mar 26, 2010 | 07:43 PM
Man this exhaust stuff gets confusing to me maybe im a little slow
So what exhaust do you guys suggest for the best Performance. Cai and gryphon already ordered and on the way
Old Mar 26, 2010 | 07:58 PM
2.25 you gain low end, 2.5 you lose low end. you have a truck witch one makes more since?
Old Mar 26, 2010 | 08:53 PM
Yogi.kudos's Avatar
Im going to order a Magnaflow x pipe from Performance Peddle. Its only $65 with the code "clubgp"
Old Mar 26, 2010 | 10:21 PM
RealTreeF150's Avatar
You can get the magnaflow knockoff for 30 on ebay, just go on e-bay and type in "x-pipe"
Old Mar 26, 2010 | 10:56 PM
avfrog's Avatar
^ agreed. Identical replica too.
Old Mar 27, 2010 | 09:55 AM
My exhaust guy fabricated it into my intermediate pipes, it works, but not to well. If I ever put in a real X pipe I will take that opportunity to get the $50 stainless one off ebay in 2.25" and convert to 2.25" duals.
Old Mar 27, 2010 | 10:38 AM
ok awesome stuff I think im gonna get the xpipe off ebay,and I will be going the 2.25 route,so thanks for the help everyone!
