suggestions for exhuast...
Old Mar 22, 2010 | 03:08 PM
Shoreboy21's Avatar
When you have a 1 chamber muffler compared to a 4 or 5 chamber muffler. It alots more flow and less restriction. Just like yelling in one BIG ROOM or yelling in a house with the same room broken up into 4 or 5 rooms. Honestly if i were you id run trual dual straight pipes..aka catbacks. maybe mix it up with an X pipe or H pipe..you would still pass all emissions tests b/c your not cutting out any cats and your going to have a great sounding truck..My 02 f150 4.6 had 2 1/4" running pipes true dual catbacks to 3 1/2" stainless tips..and was one of the loudest f-150 ive heard..
Old Mar 22, 2010 | 08:16 PM
avfrog's Avatar
Originally Posted by Shoreboy21
the only reason i would caution the 40 series is b/c your still talkin a 4 chamber muffler. the 10 series has one chamber and has an amazing sound. **** most places that sell 10 series will tell you they dont make em...
Umm... a 40 series is a 2 chamber muffler there pal.
Old Mar 22, 2010 | 08:27 PM
Shoreboy21's Avatar
ok cool as long as the right info is going to him...so thanks for clearing it up..i like true dual straight pipes.maybe with an x pipe to mix it up a bit..but to each his own
Old Mar 22, 2010 | 08:36 PM
avfrog's Avatar
To each his own agreed. The X pipe will smooth the sound and tone down on the pop and crackle. I am also partial to the X pipe. It is also known to make a few more numbers on the dyno sheet.
Old Mar 22, 2010 | 08:41 PM
Shoreboy21's Avatar
I have always heard an X-pipe will add torque and an H-pipe will add HP..i dunno how much of that is true..
Old Mar 22, 2010 | 08:48 PM
Its all true. Except in trucks with offset pipes, meaning the left bank is guided over to the driver side and runs along the passenger bank exhaust.
X pipe helps with low end torque which helps move the weight of the heavy truck, H pipe flows more direct which is best when WOT.
Old Mar 22, 2010 | 11:35 PM
big_gun's Avatar
so what would be better a h pipe or x pipe.....i dont do any towing, just my back and forth truck for school & football
Old Mar 22, 2010 | 11:45 PM
H pipe if you race now and then. Otherwise X pipe performs better moving around the neighborhood, and deletes the amount of annoying rasp and crackle to a very low minimum.
Old Mar 23, 2010 | 09:46 PM
avfrog's Avatar
X ftw!
