Homemade intake question
Old Feb 17, 2010 | 02:18 AM
Overlord71's Avatar
Heres the question I have a 1997 F150 4.6L V8. Im just wanting to know how much a new mass air flow would be? I plan on tiging up some aluminum pipe and making whole new intake. But the giant stock mass air flow is to big and bulky..
I would really like to find a mass air flow that would be convient for this little project..
Thanks.
Old Feb 17, 2010 | 05:22 AM
Veteran: Army
you don't need a larger MAF unless you go to forced induction
Old Feb 17, 2010 | 01:49 PM
Overlord71's Avatar
Home made intake
But if I was going to make it at home with something like 2.5"pipe then the stock MAF would not slide into my new intake..
I think I may not have asked my question very well. So if I was to go about building a new intake. I was wondering if they made a thin MAF or even a MAF that would attach to my throttle body or if the MAF can be placed between the pipe and the air filter?
thanks.
Old Feb 17, 2010 | 03:05 PM
MGDfan's Avatar
Hello Overlord!
Welcome and greetings!
Sir - A few things I'd like to note with yer permission:
Please be advised that reducing the overall diameter of yer intake could compromise performance.
Also - the factory MAF is more than adequate to meet the needs of a stock or even mildly built bolt-on motor.
Further - the stock MAF's flow characteristics are firmly married to the specific tuning in yer truck's PCM - any changes/replacement of the MAF itself - even perhaps extreme location changes, can adversly affect the safe running of yer truck. The onlt solution is a custom tune to correct the affected transfer function.
Lastly - aluminum is, perhaps, not the best material here - it exhibits vigorous heat transfer in high-ambient & heat-soak conditions. ABS / PVC would be better ( and easier to work with ). Stangely enough, stainless appears best (polished on the outside, matte on the inside).
You can also explore the Gott's mod on this site, and/or the other various intake modes, to give you some additional ideas - just a quick Search away.
Thanks!
Cheers & Bests!
MGD v2.1b
Old Feb 17, 2010 | 08:06 PM
avfrog's Avatar
^ agreed
