intake choices?
Old Feb 9, 2010 | 06:38 AM
Pballman19's Avatar
intake choices?
we cant do the gotts mod on our trucks, and im pretty sure what i have will be better than a K&N,
so what else is out there
Old Feb 9, 2010 | 01:37 PM
What exactly is 'our' trucks? Do you have a 2009+? Or a pre '97- model?
Old Feb 9, 2010 | 01:49 PM
Blumpkin's Avatar
Yeah if your truck is a 98-present model you can't do the gotts mod, but you can do the DWV mod which is basically the same thing just applied to the newer trucks.
Old Feb 9, 2010 | 07:24 PM
avfrog's Avatar
I have an $80 CAI off of ebay, and it came with a K&N cone. I have zero complaints.
Old Feb 10, 2010 | 04:01 AM
Veteran: Army
so what you're stating is that it didn't work for you or you are confused?????
FYI, the gotts mod was designed around the 2 valve motors (first documented on a '99 5.4) and works all the way up to the '08, 2 valve motors
the DMV mod is for the 3 valve motors ('04-'08/'09ish)
Old Feb 10, 2010 | 02:09 PM
Blumpkin's Avatar
Sorry i was thinking 04-present but i ended up typing 98-present.
Old Feb 10, 2010 | 04:03 PM
shifty_85's Avatar
the names of CAI is endless. no names on Ebay K&N AF1 Air raid specter. it depends what you want shiney/ plastic/open/enclosed/oil/dry theres alot of CAI out there they all do the same thing 90% of the time you pay for the name on it. my K&N77 cost me 230 bucks.
Old Feb 10, 2010 | 04:13 PM
It would really help if you would include your truck year and engine in your profile. If not, when you ask a question, you always need to include that info in the question.
Old Feb 11, 2010 | 12:24 AM
97XL's Avatar
If you can find one..(they went out of business last year) the AF1 is good. Just make sure that if you do find one and the intake tube is the 3.5" version you will DEFINITELY need a tune for it or you will run scary lean. From what I've researched the 3.25" tube can be run with the stock tune.
There might be some used ones or just sitting on a shelf somewhere out there.
Old Feb 11, 2010 | 10:59 AM
Pballman19's Avatar
umm, i definitly assumed my signature would have posted, and yall woulda known what my truck was. but i guess it decided not to.
i have an '06 superduty
Old Feb 11, 2010 | 11:00 AM
Pballman19's Avatar
see, why couldnt my sig post the first time, wtf
Old Feb 11, 2010 | 03:10 PM
XtremeBawls's Avatar
If you do a quick reply it defaults to add your sig, but if you click go advanced you have to select the check box to enable your sig when you post.
Old Feb 12, 2010 | 01:16 PM
Pballman19's Avatar
i see
