Removing all 4 cats
Old Jan 18, 2010 | 05:52 PM
F1504.2LPhil's Avatar
Removing all 4 cats
Can I delete all 4 cats without getting a tune? Thanks
Old Jan 18, 2010 | 06:03 PM
f150fella08's Avatar
you sure can!!!!!!!!!!
will it run right, no
Old Jan 18, 2010 | 06:17 PM
So if my cats are clogged what would you suggest? Dont have emmissions in florida
Old Jan 18, 2010 | 06:45 PM
Blue02FX4's Avatar
have em all chopped off and have a shop replace with some pipe and some high flow cats! that should fix your plugged cat problem and still not set of a CEL
Old Jan 18, 2010 | 06:59 PM
What about my rear o2's, what do i do with them. In my Z28 I had them tuned out of the ECM, can I do the same with a f150? Also what size is the piping for the high flow cats?
Old Jan 18, 2010 | 07:04 PM
yetti96's Avatar
More info on the truck? ow are they clogged? And we do have emissions laws in FL, made up for the whole nation. If all 4 are bad I suggest 2 hi-flows to remain legal, keep the CEL away, and not sound too obnoxious.
Old Jan 18, 2010 | 08:51 PM
2003 f150 4.2L 5spd 4x4. Tell me if this would work out? The cats closest to the manifolds gut, then cut off the rears and put pipe in there place, buy MIL Eliminators to trick the computer, then do some sort of catback?
Old Jan 18, 2010 | 11:47 PM
cut all 4 off, and replace with 2 high flow cats, or 4 if you have emissions
Old Jan 19, 2010 | 02:15 AM
x2.
Old Jan 19, 2010 | 11:13 AM
x3.
Old Jan 19, 2010 | 02:36 PM
Gotts2BMe's Avatar
it will run just fine...
Old Jan 19, 2010 | 08:49 PM
avfrog's Avatar
Cut them out and do the Gotts mod on your o2's.
