need advice.
Old Jan 10, 2010 | 12:32 PM
EVIL_SVT's Avatar
need advice.
Ok so I narrowed it down. I want to change my stock exit in front of the pass rear tire cat back. I love the kits for there quality and direct fit. I am worried about losing bottom end power. If I were to get a kit the one that I'm looking at is the Magnaflow:
PART # 15609
V8 4.6L Extended Cab Pickup, GAS, 78.0 Bed Length
5 x 8 x 24 in. Muffler, 3 in. Tubing, 4 in. Tip, SINGLE REAR SIDE EXIT
The other option is just to buy the muffler and have a local shop make me one with a smaller diameter pipe and maybe a 3" tip just for looks. So my question is, which would be better for what I'm looking for? I have a 169,000 miles on a stock 4.6L other than the Spectre CAI. Again I just want it to look better with out hurting any power. I even like how quite it is. My Lightning was so loud I wanted to blow my brains out after 10 minutes of driving so quite is a nice change.
Old Jan 10, 2010 | 02:28 PM
avfrog's Avatar
3" single kit like that one ^ should not loose any power.
Old Jan 11, 2010 | 11:43 AM
EVIL_SVT's Avatar
Loosing low end would really bother me seeing how all I'm looking for is longevity and something that looks better than the stocker that's on there now. It's a bit pricey so I'll save up and get done for spring.
Thanks for the input
Old Jan 11, 2010 | 06:53 PM
avfrog's Avatar
^ Ya I suggest rolling with that set up.
Old Jan 12, 2010 | 12:06 AM
EVIL_SVT's Avatar
Thanks, I went to a local exhaust guy that I've used in the past. He has SS pipe and a Mandrel Bender. A custom set up is very close in price to that Magnaflow kit. If the Magnaflow is half of the quality of the Bassani that i had on my 95 Lightning it will be ok by me. Thanks for your help guys.
While I got you guys, do you think it's to my advantage to replace the cats? If I'm not mistaken I have 4 on my truck. Two resonators and two cats, is that correct? My exhaust is all original but suprisingly enough it's in really really good shape. Mainly I just want to improve power, mpg's (.5mpg if i'm lucky). The only other mod I have and it's still in the box is a Spectre CAI from http://www.autoanything.com/air-inta...A4368A0A0.aspx $140.00 shipped. I will post pictures of the install probably this weekend.
Thanks again for your help, I've been on the http://www.nloc.net/ since it began and just like here with people like you they have been and invaluable help to me. I'm handy with a wrench but by no means a auto mechanic. You guys make it to easy sometimes.
Old Jan 12, 2010 | 12:32 AM
The front cats aren't just resonators, they are cats too, but in your model they aren't the real gas filtering cats. If you want a louder sound change them to hi-flow cats.
Old Jan 12, 2010 | 03:11 AM
EVIL_SVT's Avatar
I don't really want a loud/drone sound. A little more rumble would be okay. My main concern is power loss. I also want longevity and that Magnaflow kit looks quality. I'm just trying to make the best decision I can for that kind of money. My last truck cost lots of $$$ just getting the exhaust right mainly because I didn't do my homework. Thanks again for the help.
Old Jan 12, 2010 | 04:30 AM
openclasspro#11's Avatar
on a 4.6 ,have him him redo tailpipe in oem size in ss, on my 5.4 i put this kit on my 5.4-i noticed a drop in bottom end tq when i towed- food for thought
Old Jan 12, 2010 | 07:41 AM
MGDfan's Avatar
^^ x2 ^^
Noticed the same on a 4.6. 3" on a stock 4.6 is a little too big. You want to maintain, or better yet, enhance exhaust gas velocity (the attribute that exludes FartMasters from any sort of real performance claim - silly little baffles wreak havoc on same).
Go with a 2.5" custom (mandrel). While you are under there, get that factory 'Y' pipe replaced with a Maggie 2.5" 'Y'. If you cut the factory one open you will be astounded with how chitty it looks - a huge , needless restriction.
Phil!
Old Jan 12, 2010 | 08:51 AM
EVIL_SVT's Avatar
Originally Posted by MGDfan
^^ x2 ^^
Phil!
Awesome, thanks for chiming in. I remember even with my Gen1 Lightning and all the mods it had, the fatter pipes made me loose a noticable low end loss but it's didn't bother that much to me because the motor work and blower made up for it and then some. On my 97 4.6L I feared it would kill my low end specially when towing. The 4.6L IMO is a bit doggish. I drive her like I'm driving Ms. Daisy around with the high milage I don't want to beat her up ya know.
I hope this isn't a dumb question but where can I get that Maggie 2.5" Y?
Old Jan 12, 2010 | 09:01 AM
MGDfan's Avatar
I got mine from a local exhaust shop who carries/can order Maggie components. It looks like this:
http://www.troyerperformance.com/cgi...atalogno=10778
The link above details how it is used, but is intended for a 3" system from the 'Y' back.
This is the actual 2.5<--> 2.5" part that will keep the entire system 2.5".:
http://www.troyerperformance.com/cgi...atalogno=10768
As you can see, they are not expensive. Add that piece of mandrel-bent crossover as described in the first linky, and you are golden. 2.5" is best to retain your low-end torque, IMHO. The 4.6 has a dearth of it to begin with.
Good luck.
