emissions
Old Dec 16, 2009 | 12:53 PM
nate3410's Avatar
emissions
I have an 04 f150. I am getting approx 11 mpg on the highway. What are the consequences if I gut my cat? Are there any other emissions that i can remove to help improve my mpg?
Old Dec 16, 2009 | 01:06 PM
2001 5.4's Avatar
you might get a check engine light which will cause a failed inspection if its on. idk wwhy youre only gettin 11. check your tire pressure and re-grease your bearings. also true dual exhaust and a cold air intake will help increase mpg's...not a ton but it will go up. also a tuner.
Old Dec 16, 2009 | 01:13 PM
nate3410's Avatar
i have aftermarket exhaust, and a cold air intake. tire pressure is where it should be. i just had the pos truck serviced and had them grease everything. think a pound of c4 will solve my problem?
Old Dec 16, 2009 | 01:28 PM
2001 5.4's Avatar
yea that aughta make ur mpg's and the whole truck go way up, literally lol
Old Dec 16, 2009 | 02:49 PM
An 04 getting 11mpg? Thats pretty bad, there must be something wrong within the engine. There are guys with 35s and 6" lifts regeared and still retain 13 - 16mpg average.
Have you changed spark plugs? Try any fuel injector cleaner?
If you gut your cat and leave the interior space open it will hurt your performance and fuel mileage even more. Replace the cats with pipe, or cut them open and have pipe ran through them to retain proper velocity pressure and you will be ok, not legally, but it will flow right.
Old Dec 16, 2009 | 03:39 PM
nate3410's Avatar
I have had all injectors pulled out and cleaned. spark plugs are fine. I have had my truck in 4 different ford shops and they can not tell me what is wrong. One shop had a diagnostic reader hooked to my computer while they were driving, and it showed that my truck wasnt running at full, but they couldnt say what was wrong.
Old Dec 16, 2009 | 03:42 PM
avfrog's Avatar
If you take them cats out you must tune for the proper fuel/air ratio, or gas mileage will go down.
Old Dec 16, 2009 | 03:44 PM
avfrog's Avatar
Maybe bad fuel your putting in it?
avfrog's Avatar
The more corn in fuel = worse mpg.
Old Dec 16, 2009 | 03:47 PM
nate3410's Avatar
i have a hard time believing that it is bad fuel. it has been like this for over a year. any performance mods that i can do that will help?
Old Dec 16, 2009 | 06:49 PM
f150fella08's Avatar
if your asking about emissions you shouldnt mess with your cats...but maybe they are clogged????
Old Dec 16, 2009 | 06:58 PM
avfrog's Avatar
^ Could be. They may have clogged up years ago.
Old Dec 16, 2009 | 07:20 PM
^ Trying out your style Av
It is a possibility, but these newer cats should not be clogging our burning out yet. They should last much longer than the older cats older trucks came provided with, but hey, with an improper fuel ratio and a rich running engine, catalyst failure is a possibility, though the engine light would illuminate indication the error.
