Good or Bad idea?
Old Dec 13, 2009 | 09:03 AM
fordman18's Avatar
Good or Bad idea?
well i finally got some pipes running after my precats. i was pretty tired with the drone and my *** vibrating 24/7. but anywho.
left my truck at the shop. drove it away. then finally looked at what they did.
is it good or bad to run 2 pipes running of both cats?. its sorta what i wanted? but idkk heres some pics. and i am finally adding pics of my truck in my album there not very good though lol
Old Dec 13, 2009 | 09:47 AM
f150fella08's Avatar
umm..
so you have true duals...with only precats, and turn downs..
which mufflers do you have? no matter what you do that setup will drone and "vibrate your ***"
Old Dec 13, 2009 | 09:50 AM
What are you trying to ask? If its ok to only be running two cats? Well duh! 4 cats is way too much, two cats will be fine, especially our 2004 pre-cats. They handle the fumes well, with only a mild cat-less scent.
Old Dec 13, 2009 | 08:37 PM
MudTerrain's Avatar
You have a pipe running from each precat, turned down, with no crossover?
I'd have an H pipe welded in for better performance, or an X to quiet the exhaust down even more...
