My exhaust thread: V6 haters DO NOT ENTER!
exactly, no need for an x-pipe on an even-firing motor.
idk, id be tempted to leave off the x and then if you get it done and it sounds like it needs it then id try it out. but i doubt it will.
although...my dumped SI/DO flow 40 pops like a ****
well, some engines need a X or H pipe on duals because of the way they fire and run, my 3.8L mustang did not, because it was a even firing engine, a odd firing engine will need a H or X pipe.
I could be wrong, but I am pretty sure I am right, IF you have a even firing engine ( one fires on left then one on right and so on ) and not a odd ( two on one side, two on the other ) you may not need a X or H pipe.
It will tone down the popping. Even on a even firing motor.
Open class, you drive a damn van so I would shut up if I were you.
Yes I have very little bottom end. I said earlier I dont tow and I never put any weight on it, maybe it will stop it from lighting the tires up so easy.
I wish mine was a bit louder but it sounds great at higher rpms, but that's only because I have a 50 series muffler. I wonder how it would sound with a 40 series. Don't knock on vans, I used to have a 87 e-150 with a 351w. I loved that engine.
You loved the motor, not the fact that you were driving something a child molester would use to coress kids in. Should of dropped that motor and threw it in a Pony.
as BOM takes his foot out of his mouth
i'll shut up -d-----bag,i list a van , i don't list all my toys, but actually i own 10 vans-2004-2010's- as i own my own hvac company, fwiw-i have the title to every van as well as all my other toys as well as the deed to my estate,so yeah i drive a van, but it has gotten me everything i own-
