High flow cats or not
Old Oct 27, 2009 | 12:35 AM
five0merc's Avatar
I have a 97 with the 4.6 and do a bit of towing so i was wondering if i cut the back cats out do i leave the front ones or replace them with high flow? I have true dual setup right now and am going to be putting on long tube headers and was just wondering about my cat situation. thank you for any help.
Old Oct 27, 2009 | 01:05 AM
Replace all 4 to be legal and have no CEL, remove the rears only and add O2 sims to keep CEL off and have a nice real loud rumble. But with Longtube headers you will not be able to run the pre-cats so get hi-flows.
Old Oct 27, 2009 | 07:46 PM
five0merc's Avatar
ok thanks. im not too worried about it being legal cause we dont have smog in north dakota
Old Oct 27, 2009 | 09:14 PM
avfrog's Avatar
No cats it is!
Old Oct 27, 2009 | 09:19 PM
avfrog's Avatar
speaking of witch...
Old Oct 27, 2009 | 09:21 PM
did you delete your cats dude. I see you put up some vids.
Old Oct 27, 2009 | 09:44 PM
five0merc's Avatar
And I won't have the lack of torque if I keep same diameter pipe that is in there from what I have read on some other threads if I am correct??
Old Oct 28, 2009 | 02:29 AM
Long day at work? It only says no cats in his sig
Old Oct 28, 2009 | 07:09 AM
Smarta$$
When he said speaking of which I thought he meant he just did it. I had never noticed it in his sig til last night
Old Oct 28, 2009 | 08:04 AM
jbrew's Avatar
Yes, you can definitly run your forward cats, no eliminator's needed - I did it for a few years. Your still within parameters on the 97 and there's no such thing as pre-cats lol. Not sure where that came from, unless this is something new, well not on the 97's anyway.
Can't run forwards with headers, but they flow about the same as High Flows.
With those headers on the 97, you'll need spun barrel High flows if you want to keep the heat shields. The Frame mount shields, you'll miss them if you take them off lol.
Old Oct 28, 2009 | 07:12 PM
avfrog's Avatar
Smarta$$
My videos just finished uploading when I said that. I should have elaborated...
Old Oct 28, 2009 | 07:19 PM
five0merc's Avatar
Ok thanks that helps out. I just wanted to see my options and didn't want to lose any of the torque.
Old Oct 28, 2009 | 07:27 PM
avfrog's Avatar
So what's the finial decision?
Old Oct 28, 2009 | 07:47 PM
five0merc's Avatar
Gonna start off with just the back cats off and then probably end up with all four off when I get my headers ordered.
Old Oct 28, 2009 | 07:53 PM
avfrog's Avatar
Now that sounds like a plan
