Need new exhaust (Help)
Old Oct 21, 2009 | 04:31 PM
PR Lariat's Avatar
Question Need new exhaust (Help)
I currently have a SI/DO exhaust no cats with the exit in front of the rear tire. I need to change it because I bought a body kit and the exhaust exit interferes with the body kit. Later I would like to install an eaton blower. The question is wich way should I go?
1.true duals with 2.25" tubing
2.true duals with 2.5" tubing
3.single exit with 2.5" tubing
4.single exit with 3" tubing
I am looking for performance I don't really care much about sound. Remember I do not have any of the cats. I don't really know if the cats issue affects the tubing diameter but i think that is an important fact.
I will greatly appreciate your input.
Old Oct 21, 2009 | 06:35 PM
f150fella08's Avatar
number 1. i believe, but you might wanna get some high flow cats on there
Old Oct 21, 2009 | 06:45 PM
PR Lariat's Avatar
Why the high flow cats?
Old Oct 21, 2009 | 06:47 PM
i just know when i took my cats off my truck lost power. and if your going to run new mufflers for power you would wanna do a straight through magnaflow or bassani or borla or something
Old Oct 21, 2009 | 06:51 PM
MudTerrain's Avatar
Definately #2 if you're getting a blower... and you won't need cats.
Old Oct 21, 2009 | 07:01 PM
PR Lariat's Avatar
I was thinking about this muffler maganaflow 12568 that has the x pipe inside. Even though the muffler is 2.5" in and out I was thinking to continue the 2.5" tubing to the inlet and at the exit install 2.25" tubing for now and when I install the supercharger i could change that 2.25" tubing to 2.5" for better flow. It is a good idea?
Old Oct 21, 2009 | 07:49 PM
#2. 2.5 trues with a X pipe.
Old Oct 22, 2009 | 08:17 PM
PR Lariat's Avatar
Thanks for the input guys. Any opinions on the magnaflow 12568 muffler?
Old Oct 22, 2009 | 09:29 PM
it'll be a bit calm but a good muffler.
Old Oct 22, 2009 | 11:13 PM
Darknightmare's Avatar
For those of you running an x-pipe, were they custom made or bought. I haven't found one through searching.
Old Oct 23, 2009 | 12:17 AM
Must not have searched hard enough, they're everywhere.
http://www.summitracing.com/parts/MPE-10791/
Old Oct 23, 2009 | 06:15 PM
Guilty. Im used to searching **** for the stang. Also I know these are noob questions, but this won't void a warrenty will it?
Old Oct 23, 2009 | 09:59 PM
avfrog's Avatar
number 1 you don't need hi flow cats
number 2 true duals with X pipe X2
ebay is a good place for cheap X. Mine is magnaflow, but ebay has a knock off that is identical for $30.
Old Oct 28, 2009 | 01:31 AM
PR Lariat's Avatar
Today I have ordered the magnaflow 12568. I can't wait to have it installed.
Old Oct 28, 2009 | 08:17 PM
avfrog's Avatar
exciting isn't it?
