Truck won't start!
Old Sep 26, 2009 | 10:58 PM
HornetDriver's Avatar
Truck won't start!
I'm pretty sure I already know what you all are going to tell me but here goes... I have an '06 V8 5.4L F150 and I just installed my K&N CAI. When I turn the key the truck starts and immediately goes to about 2200 RPM then slowly comes down, as its dying the panel says Engine Failsafe Mode and then I quickly turn the key off. It sounds like the engine is getting flooded. I've heard rumors that on some Fords if you don't get a programmer and install a CAI that this would happen. I thought that was older models though, and I heard that an '06 would be fine. Any ideas?
Old Sep 26, 2009 | 11:13 PM
maybe the filter was over oiled and you need to clean the MAF
Old Sep 26, 2009 | 11:22 PM
x2 on the over oiled part. You need to be careful with those K&Ns.
Old Sep 26, 2009 | 11:32 PM
the MAF is the original, not from K&N.
Old Sep 26, 2009 | 11:35 PM
no, he means the oil in the K&N may have been applied excessively and its clogged the MAF.
I get it, sorry, read it wrong, I'll check it out, thanks
Old Sep 27, 2009 | 08:47 AM
openclasspro#11's Avatar
is plug in sceurely?put oem air cleaner on and see if problem is still there
Old Sep 27, 2009 | 09:18 PM
Ok, cleaned the MAF and the truck starts fine. 3 more questions...I have a check engine light. Is that because I have to get a programmer? Next, there is a pretty good whistle that comes from the intake when I hit the throttle, is that normal? Once I get up towards WOT, the rumble that I'm use to with a CAI comes in and the whistle goes away. Lastly, it says I'm getting 6MPG, is that extremely inaccurate because I dont have a programmer, or is it that my current FCU is flooding the engine?
Old Sep 27, 2009 | 09:53 PM
Dstang's Avatar
I've had CAI on many cars and trucks and all whistle a little bit thats normal...is it reading 6mpg when your WOT or at cruising speed?
