94106 Magnaflows question.
Old Sep 24, 2009 | 06:43 PM
fordman18's Avatar
ok just cause im 18 and have no idea what im doing hahaa. umm if i want to replace my cats now with the magnaflow 94016's is it the same size like wide? as the stock cat?
if you dont get what im trying to say ill try and reword it lol
Old Sep 24, 2009 | 07:26 PM
migdaddy's Avatar
all you care about is the inlet/outlet diameter. If they are 2.5" then you are set.
Old Sep 25, 2009 | 10:20 AM
You also need to stay within the GVWR rating so they do not burn out on you. 94106 cats along with the entire 94000 line of cats are 6200 rated so you are good to go.
Old Sep 29, 2009 | 07:33 AM
fordman18's Avatar
questionn. what about the sensor? do i get one put in? or do i buy one with the hole?
Old Sep 29, 2009 | 02:22 PM
You could get the 94136 model which does have an O2 hole, but its been known to give false readings and triggering the CEL, having the O2 sensor mounted AFTER the new hi-flow cats ( 94106 model in your case ) works very well, it gives the cat a chance to filter the certain percentage of gases and the CEL reads it acceptable.
