Seems like I lost torque...??
Old Sep 23, 2009 | 09:43 PM
07 FX4's Avatar
thanks for all the help guys...its about an inch or two from where the Y pipe comes together(darren) and its crimp bent
Old Sep 23, 2009 | 10:15 PM
migdaddy's Avatar
crimp bent? im sorry. theres part of your problem. the exhaust flow is not flowing as well as it should and is being blocked by the ripples in the piping.
Old Sep 23, 2009 | 10:49 PM
That was un-necessary, yet an interesting file.
Old Sep 23, 2009 | 11:12 PM
Maxout05's Avatar
07FX4 it sounds like you got a bad deal with how they did that for you.. I think you found some issues already that are causing your problem take it back to where you had it done.
Old Sep 23, 2009 | 11:23 PM
migdaddy's Avatar
haha i see a BAN coming.
Old Sep 23, 2009 | 11:31 PM
mblouir's Avatar
pop
Old Sep 23, 2009 | 11:34 PM
Paralyzer's Avatar
i advise everybody to print out that form. they are very handy in the workplace
Old Sep 23, 2009 | 11:44 PM
oneBIG09's Avatar
Most of the time some of the problems can be corrected with a high flow intake as well.
Maxout05's Avatar
Oh man, lol!!
Old Sep 24, 2009 | 03:01 AM
gr8hntr's Avatar
Originally Posted by MudTerrain
Are you serious?
yes i am
i still stand by why would you dyno a 4x4
and are you serious is not a reason why
what we have like 300hp and exhaust gain is what ..not a hole heck of a lot
like say NOS or installin a dual screw charger
i would like to see the dyno on these mufflers
and what kinda of gains either has on the other ... a couple of hp maybe
Old Sep 24, 2009 | 07:04 AM
Veteran: Army
these bash FLowmaster threads usually end up that way
what really cracks me up is that the individuals who harp on magnaflow is the best use the dyn o results that also shows borla XSPro's outperforming the magnaflows but they conviently forget about that info, the same company dyno the X and H pipes and showed that the H pipe was a better option for under 3500 rpms but that info is also conviently forgotten about in order to continue the craze of "blacked out" trucks with X-pipes and magnaflows
in reality at the minimal power levels majority of you at you should be more concerned with what sounds good to you as you are the one who has to drive your truck daily...
this thread and others like it is the reason this site is going downhill, people should be more concerned with preserving the American tradition of Hot Rodding vs bashing something that isn't done "my way"
Old Sep 24, 2009 | 07:28 AM
Old Sep 24, 2009 | 08:54 AM
Carlsson3's Avatar
Anytime you go to a more free flowing exhaust from the factory setup you'll lose a little low end torque. Even more so if you increase pipe diameter all the way out. Decreasing back pressure results in a loss of low end torque. Oversimplified, but true. If you had a 1000 hp and 800 ft·lb on tap, it ain't gonna matter, but with a factory motor with a couple hundred hp, you're gonna notice the difference. It seems to me "crimp" or full dia. mandrel bends on an exhaust with the stock engine won't make that much of a difference. Technically measurable, but not very noticeable.
Old Sep 24, 2009 | 01:34 PM
LincolnMarkLT20's Avatar
Sound is much more important to me.
Old Sep 24, 2009 | 02:59 PM
migdaddy's Avatar
well said jerame. bunch of women, i mean little girls, on this site sometimes. tryin to make their point and say there setup is "better". some people have the mentality of a 5th grader "i know mines better because I said so"
and this doesnt apply to everyone, but it's usually the new people that come on this site thinking they know everything about everything, from exhaust to how to take apart and rebuild a motor.
