installed intake and engine light came on
Old Sep 2, 2009 | 11:33 PM
Red-04-F150's Avatar
Ok, so i just installed a aem brute force intake on my truck. 04 5.4L. right away the check engine light comes on. sometimes it will go off for a couple days but then come on again. wondering if there is anything i can do to fix this.
Old Sep 2, 2009 | 11:44 PM
If all connections are properly conncted, then you are running very very lean. Re-install your OEM intake, get a custom tune for it, and try it again.
Old Sep 3, 2009 | 12:00 AM
someone told me there is an aftermarket sensor you can get that will except the higher air flow. if not i guess i will put the stock one back in.
Old Sep 3, 2009 | 12:08 AM
MudTerrain's Avatar
Did you reinstall the MAF correctly? Same location/direction as it was stock?
Old Sep 3, 2009 | 12:14 AM
i am not sure if it is the same direction as stock but it is installed how aem tells you to. i have double checked it like 5 times.
Old Sep 3, 2009 | 12:15 AM
04s came from the factory in a near lean condition. Quite often, any extra airflow will cause one to run lean. A damaging situation and not something to play with. You should get a tuner with custom tunes that will modify the air/fuel mixture range. Too, you really can't take advantage of a CAI without a custom tune anyway. Get an Xcal3 or a Gryphon and then you will be safe.
Old Sep 3, 2009 | 01:53 AM
JDCoke's Avatar
I've got an 04 with the AEM Brute Force intake. I also had the check engine light come on. Do you have the trouble codes?
My solution to the constant lean condition...
1- Bought Superchips tuner.
2- Cleaned throttle body
3- Cleaned MAF sensor - if you have the oiled AEM filter...the oil will foul your MAF and regular cleaning is needed.
Cleaning my MAF and throttle body solved my rough idle/stalling problem and have no codes. If I get codes PO172/4..then I clean my MAF...codes go away.
Changed my plugs this past weekend...after 149K on the OEM set....probably could of gone another 100K on them...but hey....why not break a few off in the the engine and have some fun . I thank the folks at Lisle for one sweet tool and one very easy plug change.
Old Sep 3, 2009 | 02:04 AM
Veteran: Army
a superchips tuner will make the problem worse since it's a canned tuner
Old Sep 7, 2009 | 11:13 PM
alright thanks guys. looks like i will change it back and look for a tune for it.
Old Sep 9, 2009 | 03:58 PM
Veteran: Army
a custom tuned tuner not a canned tuner with custom settings
