spectre vs. K and N
Old Aug 17, 2009 | 09:27 PM
4x4Nixon's Avatar
spectre vs. K and N
why are the spectre CAI cheaper than most CAI out there? and which is better the spectre or K and N or will it basically just do the same thing?
Old Aug 17, 2009 | 10:21 PM
migdaddy's Avatar
u pay for the name and reputation. spectre uses 4" tubing vs 2.5"-3" from K&N. i would go with spectre
Old Aug 17, 2009 | 10:36 PM
MudTerrain's Avatar
You wouldn't be able to tell the difference between the two if you install them on your truck.
However, the Spectre is 4"? You may need a tune to run it properly, even on the 2V 5.4L.
Old Aug 17, 2009 | 11:08 PM
migdaddy's Avatar
negative. i spoke to a rep from spectre and i asked due to the excessive size of the piping, will it cause the truck to run lean on a 2v 5.4L motor. he said hes had many of these motors run the system, and not one came back with issues. however with the 3v as we all know, ull need that tune.
Old Aug 18, 2009 | 12:37 AM
MudTerrain's Avatar
Eh... You could talk to reps from all of the major companies (K&N, AEM, Volant, ect.) about running an intake on a 3V and all of them would say "you'd have no problems". Many of them don't truely know.
I'd get it on a dyno regardless. That's a huge freakin' pipe.
Old Aug 18, 2009 | 12:59 AM
migdaddy's Avatar
yea true dat! 4" is definately big. it sounds so badass on my buddies 5.3L chevy.
Old Aug 18, 2009 | 08:37 PM
redphantom01's Avatar
I have the spectre cold air intake on my 2001 screw 5.4 (2V) and it works just find. I didn't have to reprogram the computer . I can tell a difference in my truck with it on. the truck seems to be louder and the throttle response is better. And with it on it has not thrown any codes. It is just a bolt on kit. you can reprogram it if you want to get more power.
Old Aug 18, 2009 | 08:56 PM
blackedoutV6's Avatar
^where did you get it from?
Old Aug 18, 2009 | 11:13 PM
I got mine from AutoZone.
Old Aug 19, 2009 | 10:16 PM
ctbutler2780's Avatar
I have the spec. intake on my expedition.. the only complaint is the filter is freakin long I need to figure out how to relocate the radiator reservoir so i can get better and cooler airflow to it. If it your intake makes a funny noise you'll need a new idle air control valve.
Old Aug 19, 2009 | 10:45 PM
Veteran: Army
unless you change the MAF size the 2 valve motors have a hard time running lean regardless of the intake size...
