Catalytic Converter
Old Aug 11, 2009 | 09:37 AM
Gmitchell's Avatar
Question Catalytic Converter
Does anyone know a company that makes direct fit catalytic converters for 2008 f150 ...thanks
Old Aug 11, 2009 | 09:45 AM
mrolgren's Avatar
Magnaflows.
Old Aug 11, 2009 | 10:03 AM
TJ05FX4's Avatar
Depends on what you mean by direct fit. The factory cats are welded in, so there isnt' anything you could just "unbolt" and put a new one in if that's what you are asking.
Magnaflow makes many universal ones, but because the stock cats are welded in, there isn't anything that just fits. They will all require a shop or welder to get the old ones out and new ones in.
Old Aug 11, 2009 | 10:49 AM
4.6 Punisher's Avatar
X2
94106 is the part number I believe and they are going to have to be welded in, no way around that.
Old Aug 11, 2009 | 11:32 AM
Actually yes you can. Their direct fit kits un-bolt it at the clamp in the Y pipe and before the manifolds.
Old Aug 12, 2009 | 10:39 PM
urmomwarnedu's Avatar
2008 cats
AAAAHHHHHHRRRHHH new guy here wondering if anyone else is havin problems with thier cats....my 08 with 40,000 kms has been in the shop for over two weeks and they tell me they cant get converters till October 10...and I use my truck for work. you say magnaflow has them?????
Old Aug 12, 2009 | 10:43 PM
Buy the parts from performancepeddler.com and do a part number search on 94006. That's the one you need and it will be SOOOOOOOOOOOOOOOOOOOOO much cheaper than what a shop will charge.
Old Aug 13, 2009 | 07:24 AM
mrolgren's Avatar
^ x2 purchase them online and have the shop install... much easier and cheaper that way!
Old Aug 17, 2009 | 11:09 AM
Had my muffler guy order some converters...got them overnight,had the dealership bring my truck over and had it the next day. $1300.00 for converters and my ford wont pay for them cause they arent "ford" parts. I am ready to burn down this stealership Im tellin ya
Old Aug 17, 2009 | 01:44 PM
marcus1033's Avatar
You could have put the magnaflow's in for atleast $1,100 cheaper. Seems like it would be the dealerships problem for not checking into what was being installed.
Old Aug 17, 2009 | 03:12 PM
Where's the Bender laugh when you need it?
Old Aug 20, 2009 | 02:39 AM
JGP2009's Avatar
I have a 2005 f150 5.4 how can ya tell if the cats are stopped up without having to cut them off and see? reason im asking is what would some of yall do cut them off and have a tune cut the o2 sensors off where it doesnt turn the check engine light on or put magnaflow hf cats on it? im trying to figure this out bacause i know how i want my exhaust but i need some input and i will have mufflers so there will be some back pressure on the system.
Old Aug 20, 2009 | 11:40 AM
If you experiencing an economy drop, or quieter exhaust note, and a possible burnt exhaust smell, you'll have a plugged/burnt cat.
I would run Magnaflow cats before running cat-less, legal so you prevent the fine, and better sounding with a massive volume increase.
Old Aug 20, 2009 | 09:06 PM
JGP2009's Avatar
Cool
Thanks i was wondering i don't mind buying the high flows but i know how the older trucks sounded with no cats but reason i asked about them maybe being stopped up is because sometimes the truck with take off like a shot rabbit and other times is like a damn dead turtle, it will get up to 4000 rpms and like hold and barely gain, any ideas?
Old Jan 10, 2011 | 08:19 PM
foxtrucker76's Avatar
i have a 2006 f150 w a clogged cat. It is the direct fit from factory however i took it to a shop and they said all they could get for it was the 2 cat system for either side. where can i find the single cat like mine w the ability to still have my 02 sensor. i found direct fit cats but none of them have the 02 sensor stud
