true dual setup
Old Aug 9, 2009 | 05:35 PM
LOHfootball53's Avatar
true dual setup
I need to get an opinion from yall for a true dual setup on my '99 5.4. How does 2 94306 high flow cats with an H pipe to two 11" (or possibly 14") Magnaflow mufflers turned down sound to yall? It's 2.5" pipe by the way. I am still trying to figure out if I want to turn it down before or after the axle. If you have any suggestions please feel free to chime in. I just want to do this right the first time. Thanks in advance.
Old Aug 9, 2009 | 06:22 PM
Sounds alright. Might lose a little low end power but nothing noticeable unless your hauling a 4,000lb+ load.
Old Aug 9, 2009 | 06:26 PM
The H will give me a choppier sound correct? I dont want a raspy sound.
Old Aug 9, 2009 | 06:29 PM
a little, it'll be as loud as no crossover, but not raspy. Running no cats or no mufflers is where rasp comes from.
My exhaust is far from raspy and its pretty much what your building.
Old Aug 9, 2009 | 06:31 PM
Yea I want a system similar to yours. The only difference is that I will be dumping mine.
Old Aug 10, 2009 | 07:49 PM
bump
Old Aug 10, 2009 | 08:45 PM
migdaddy's Avatar
why dump?
Old Aug 10, 2009 | 08:55 PM
i dont like the look of tips really.
Old Aug 10, 2009 | 08:57 PM
migdaddy's Avatar
at least dump it over the axle. itll give it a better sound
Old Aug 10, 2009 | 08:58 PM
thats what i'm having trouble deciding. whether to go over the axle or not. i want a good bit of interior sound.
Old Aug 10, 2009 | 09:53 PM
openclasspro#11's Avatar
true if u use 2.5",with my 2.25" setup-in my 9k lb van- i tow ~5500 lbs every weekend-my torque band is lower than with my oem stock 3" single exhaust and was lowered in the rpm range...
Old Aug 10, 2009 | 10:00 PM
yea, i know 2.25 will boost torque. but i dont tow often at all. and im doing this for sound mainly.
Old Aug 10, 2009 | 10:54 PM
migdaddy's Avatar
u mainly want sound? go dual 11" magnaflows (i would do bullets but thats just me) H pipe, 2.5" piping and if ur set on dumping it, dump it over the axle. itll sound pretty damn good
Old Aug 11, 2009 | 07:08 AM
yea thats my plan for the setup. along with high flows.
Old Aug 11, 2009 | 07:29 AM
Veteran: Army
the H-pipe will give more chop
