2005 f150 iat sensor
Old Aug 9, 2009 | 01:00 AM
DARKNITE's Avatar
WHERE, ON MY 2005 4.6l V8 F150,
will I find the Intake Air Temp. sensor?
Old Aug 10, 2009 | 01:08 PM
DARKNITE's Avatar
Intake air temp sensor 2005 F150
I just picked up a performance module, and it should be wired in to the IAT sensor. I am not sure of the location of the sensor, and could use a little help finding it. Any help, guys?
Old Aug 10, 2009 | 01:22 PM
its mounted on the intake tube between the MAF and the TB
where did you order the "performance module" from?
Those are usually just a resistor that lies to the computer about the air temperature coming in, and makes the vehicle think the air is colder then it is, so the computer allows more fuel into the engine. Doesnt really help performance, just hurts your economy.
Old Aug 10, 2009 | 01:33 PM
DARKNITE's Avatar
It is a BOSS module, and they say it is not just a resistor. 35-45 hp, and about 3-5 mpg. I have a 4.6L V8.
Old Aug 10, 2009 | 01:34 PM
good luck with that. Dont you think that if all Ford had to do was add in a little "module" that increases horse power by 15-20% that they would be doing it already?
Old Aug 10, 2009 | 01:45 PM
ONELOWF's Avatar
I believe what the module will do is to lower the air intake temp data that the pcm receives. So, the pcm will see lower temps and add timing, etc. Not a good game to play.
Old Aug 11, 2009 | 02:57 AM
DARKNITE's Avatar
'05 F150 4.6L and IAT location
I have a module that is supposed to work better connected to the Intake Air
Temp. sensor. I could use a clear definition of the location, and maybe a site where a good clear picture is? Any help from this group would be appreciated.
Old Aug 11, 2009 | 09:24 AM
Veteran: Army
you didn't buy one of the worthless ebay waste-o-money gimmicks did you?????
if you did you better return it before you do some damage to your truck
Old Aug 11, 2009 | 09:26 AM
Veteran: Army
he did order one of the gimmicks
his poor truck
Old Aug 11, 2009 | 09:29 AM
Veteran: Army
so you have 3 threads because you want to install a gimmick on your truck????
hope you saved enough for a new motor
Old Aug 11, 2009 | 09:37 AM
All 3 threads have been merged. Please start one thread only per subject matter. Thanks.
Old Mar 8, 2012 | 04:06 PM
sam1947's Avatar
He will SOON find out what that thing REALLY cost him !!!!!
Old Mar 8, 2012 | 04:25 PM
I hope he did, it was 3 years ago
Old Mar 8, 2012 | 06:58 PM
sam1947's Avatar
Could be that's we don't have the outcome of this AND (once again !!) I fail to read !!!!! LOL
Old Mar 8, 2012 | 08:07 PM
It would make for a good read
