What high flow cats to get?
I have searched around on the forum, but I haven't come to any conclusion. I think that I have settled on Magnaflow cats, but I am not sure which ones to get. Any suggestions would be great.
I do plan to eventually go to true duals. Right now I have a Cherry bomb cat back SI/DO coming out in front of the pass side rear tire.
x2, Have the rear O2 sensors mounted after them and you will be fine.
Sorry if high jacking, if I go with 94106 will I need o2 extensions? when you say mounted after them, so that means before the cat on top?(closer to motor) or after the cat on bottom?
