DI/DO Side Exit??
Old Jun 23, 2009 | 11:49 AM
f150 rider's Avatar
DI/DO Side Exit??
I have found some holes in the pipes behind the muffler on my truck and am toyin with the idea of doing away with the pipes running out the back of the truck and run 2 pipes with tips out the passenger side or drivers side? any ideas on this setup? fix the pipes or run new out the side? it has magnaflow high flow cats into DI/DO built in X-pipe Magnaflow muffler on it now.
Thanks!
Samuel
Old Jun 23, 2009 | 11:59 AM
You could definitely run it before tire. Your muffler may need mounted forward though depending how far back it currently is. It will have a little more volume to it.
Old Jun 23, 2009 | 12:51 PM
f150 rider's Avatar
Hey Darren! I just thought about something else I could dump it behind the muffler? but i think it would look/sound better run out the side before the rear wheel on the passenger side, also if i run it out the side the muffler will have to be slid forward alittle bit. wonder if I can reuse the stainless steel tips that are on there now? they are 3 1/2" X 18" long
Old Jun 24, 2009 | 02:43 PM
Ofcoarse you could dump it. May hum inside a little more but its definitely available.
Old Jun 24, 2009 | 03:37 PM
f150 rider's Avatar
all right she`s going in the shop tomorrow afternoon, going to move the muffler up towards the front about a foot and then run 2 pipes out the passenger side in front of the rear wheel, quoted $75 max Thanks for the advice Darren I`ll keep you`all posted on how it turns out!
Old Jun 24, 2009 | 05:11 PM
Sounds like a good deal. Looking forward to your feedback, get a new video to compare it to for current one!
