Cutting exhaust pipe back for tip?
I have a stock exhaust setup with a 14" Magnaflow muffler and want to install a 8" Gibson single wall stainless tip. The section exiting to the rear after the bend is 10". Should I cut this back before installing the tip? Appreciate any input except saying "just put duals on"!
I'm really happy with it. Definitely has more tone, slight drone on acceleration to highway speed (which actually sounds tough but not overwhelming) then smooths out and has a real good sound. Some folks may question this but I swear I got better throttle response after I had it installed. Really seemed to open the exhaust.
Hold it up to where you think it would end perfect, and mark the pipe at the spot where the tip inlet starts, and cut it about an inch after your mark so you can slip-fit and clamp it.
3" from the Y pipe will perform healthier, and have a deeper grunt.
I agree Darren....Its what I'm going to do. Just always shoping around, especially since going 2.5" would be less then half the cost of the 3"...You have me convinced to go 3" though.
