5.4L Headers?
Old Jun 3, 2009 | 04:37 PM
1997fordlariat's Avatar
5.4L Headers?
My exhaust manifolds are leaking on my 97 (typical) and I want to just put headers on so whats the best value? any ideas?
Old Jun 3, 2009 | 04:48 PM
joshua733's Avatar
i got pacesetter longtubes from summitracing.com for 280
Old Jun 4, 2009 | 12:20 AM
Longtubes for performance, shorties for just a simple replacement and a minor sound gain. Pacesetter, and Dynatech make excellent headers.
Old Jun 6, 2009 | 12:03 AM
05crewzer's Avatar
my thoughts exactly
Old Jun 6, 2009 | 09:48 AM
Veteran: Army
do you have a 4x4 or 4x2? if you have a 4x2 the OBX headers are pretty worthwhile for long tubes
Old Jun 6, 2009 | 10:13 AM
Skaz's Avatar
Yea the OBX's are nice. If you've got a 4x4 though it takes a little extra work to get the midpipes to fit.
Old Jun 11, 2009 | 12:15 PM
Didz's Avatar
Did you have any problems with the 4x4 OBX headers being inline with the transfer case drive shaft? If so what did you do?
Old Jun 11, 2009 | 12:45 PM
shifty_85's Avatar
ive ran both pacesetter shortys *220$* and pacesetter long tubes *284$* the long tubes gave me more performance the shortys were nice because they were direct bolt and i didnt need to change cats and all that.
both are great never had a prob with either. my shortys are on another members truck on here and still going strong after 3 years
Old Aug 10, 2009 | 06:01 PM
trx450er's Avatar
If I was to buy the PaceSetter long tube headers im able to buy their Y pipe and it will bolt right up to my stock cat back exhaust that I have now?
Old Aug 17, 2009 | 06:24 PM
Didz's Avatar
Arrrr
The OBX headers that I got for my truck did not work. I bought full length OBX headers for a 2005 F150 FX4 (4X4) and they did not fit. The drivers side header fell right in line with the transfer case axle. After weeks of back and forth OBX told me they didn't have a working set.
I installed Pacesetters with the Y pipe. My PS system bolted up no problems but it elminated the cats.
Installing the Long tubes is not for the inexperienced. My truck required pulling the transmission loose and backing it off the engine 8 inches or so for clearance of the passenger side header. I tried every way possible to install them otherwise and failed. Installing the headers on this truck is not easy at all. Getting to some of the bolts is very difficult. It also requires removing all the exhaust studs. Good luck getting some of those out without a stud removal tool.
