Problems with CAI on untuned 06 5.4L?
Old Jun 2, 2009 | 01:12 PM
zane.ward's Avatar
I have a 2006 5.4L f-150. I just put a new magnaflow exhaust and K&N CAI on it, and have custom tunes from Troyer on the way. My question is if I should be worried about it running to lean? I've noticed now if I really hammer it and give it all shes got it sounds like the engine is missing at first and takes a second to catch up before it takes off. Otherwise with moderate acceleration it seems fine. Gonna take the K&N off tonight anyway I think.
Thanks a ton for any advice,
Zane
Old Jun 2, 2009 | 02:45 PM
feyded1020's Avatar
While I dont have a 5.4L, I remember reading people with similar questions, and Im sure if you did a search for the 3v 5.4L you'd find the answer but Im pretty sure it was that without custom tunes, the intake causes it to run too lean.
If I were you I'd just take it off, as you stated, good luck and hope those tunes turn out well.
Old Jun 2, 2009 | 04:11 PM
06xlt4x4's Avatar
Yes that sounds like your having a problem with it running lean. I would take it off until you get your tunes in.
Old Jun 2, 2009 | 04:18 PM
If you leave it on, stay out of it. You are probably running lean at higher rpm. You don't get full benefit of a CAI without a custom tune anyway, so why put it on even, until you get your tunes?
Old Jun 2, 2009 | 10:59 PM
RebelOne's Avatar
your ECU is gonna take a little bit for it catch up....maybe a couple days. You won't have any problems with it
