removing stock ribbed intake piece
thinking of doing the gotts intake mod and was wondering if there was any way i could remove the ribbed intake piece and replace it with something smoother flowing?
thanks in advance!
thanks in advance!
a large piece of rubber coupling would probably work
check in the plumbing section of like home depot, lowes, walmart etc
let me know what you use and if it works I'll update the write up as I have for the other ideas
i looked a little closer at it today, and am not sure how to make the IAT sensor work if I was to change that piece...might could figure something out though
when you pull it out it's only pressed into a grommet, drill a small hole in the new part you use
it's' the same thing when us centrufigal guys relocate the IAT sensor to in front of the TB
well i tried this today...there's no doubt it can be done, but i couldn't find a 4.5" flexible coupler anywhere; all i have in town are ace hardware and tractor supply. by the time i realized what i needed, ace was closed and TS didn't have it. Guess i'll be looking tomorrow at ace.
But i did do the gotts intake while i was at it - and removed the silencer
...only difference i can tell is it's a little louder; i don't really feel any increase in power, but probably just as much as i would've with any name brand CAI i figure.
today i put the silencer back in...it was just a little annoying with it out; after putting it back in, i think throttle response improved. I think it directs the air to the throttle body better with it in there, rather than just letting all that air in the L-tube.
