Dumped ?
Old Mar 27, 2009 | 11:59 PM
IDNC76's Avatar
Dumped ?
im getting tired of looking at my tips. they are pretty much 2 toned right now , and i just dont like the way they look anymore. i think it would look much cleaner if they were removed.
i am not too familiar with exhaust , but what i do know is : i have magnaflow si/do . the tips exit out the sides behind the tire.
my question, can i cut off the piping at some point beyond the muffler , would i need turn downs to exit the exhaust away from the undercarriage or does it not matter ?
Old Mar 28, 2009 | 12:17 AM
scotyg's Avatar
ya, that way your not blowing exhaust over your axle/bed.
you could just do it yourself. jegs has turndowns for like $15 a piece, and they come with clamps and will just slide over your pipes.
Old Mar 28, 2009 | 12:27 AM
IDNC76's Avatar
thats sounds pretty good, i ll check out jegs , thanks
i think the piping is 2.5 " does that sound right ?
and also where is a good place to put the turn downs , before the rear axle ?
http://www.jegs.com/p/JEGS/752880/10002/-1
under turndown pairs ,
i would need either the 1 st one 2.5 id or the 2nd one 3.0 id right ?
Old Mar 28, 2009 | 01:23 AM
black5.4beast's Avatar
if you dump it before the rear axle you are much more likely to have more noise inside the cab. but if your muffler isnt that loud then dont worry. if it is tho, then you might want to save your ears and dump it after the axle
Old Mar 28, 2009 | 01:33 AM
dkgreyf150's Avatar
yea the closer you dump it to the muffler the louder the sound and lounder in cab but it really just depends on what you want
Old Mar 28, 2009 | 01:56 AM
scotyg's Avatar
if your pipes are 2.5 then get the 2.5 pair.
Old Mar 28, 2009 | 09:52 AM
bigdog87's Avatar
Just get them to cut off like right when it goes over the axle. Or, you should have bought stainless steel tips.
Old Mar 28, 2009 | 11:25 AM
IDNC76's Avatar
do i really need the turn downs
or can i just saw it off at a place were it points down ?
i mean either way the fumes will still rise right ?
Old Mar 28, 2009 | 11:31 AM
bigdog87's Avatar
Just have them cut the pipe right when it turns over the axle, virtually it's own turndown.
Old Mar 28, 2009 | 11:47 AM
scotyg's Avatar
that would work too
Old Mar 28, 2009 | 12:21 PM
coonhound130's Avatar
A turn down is to give it some sound by directing the sound to the ground and it reflects back causing a deeper tone .
Old Mar 28, 2009 | 12:31 PM
cheesepuff1's Avatar
i had my maggie dumped after muffler and it was ddeeeppp and a little loud in cab...but it sounded awesome... ity is si/do...i had it ran lighting style ...pics in my album of set up...
Old Mar 28, 2009 | 07:13 PM
FX4life's Avatar
IDNC i have some turndowns from my second exhaust system. They have hangers and everything on them and are 2.5" piping. Check my gallery 'stuff for sale'. I had completely forgot about them until i saw this thread..
