GOTTS mod question please help!!!!!
Old Feb 27, 2009 | 10:19 AM
acruzomatic's Avatar
I'm fustraited. I just wasted about 1.5hrs of my life at both Lowe's and Home Depot looking for the 3" ABS plastic pipe or whatever and can't find it anywhere. For you who have done this and purchased the materials at either one of the two listed above, can you please tell me exactly where you found it??
thanks,,,
Old Feb 27, 2009 | 10:33 AM
zing77's Avatar
You are looking for 3" PVC pipe in the plumbing section. If I were you, I'd go dumpster diving to find a scrap piece of this pipe. I doubt you will be able to get a piece at Lowe's less than 4' long. You only need a piece about 10" long max.
Old Feb 27, 2009 | 11:14 AM
my64falcon's Avatar
I got mine at Lowe's. Like zing said, its in the plumbing section. 3" PVC pipe. I paid about $6 for a 2' piece.
Old Feb 27, 2009 | 11:57 AM
Is it white or black in color???
Old Feb 27, 2009 | 12:08 PM
31 YNOT's Avatar
doesnt matter, what i bought is white it was cheaper and the coupler is black and covers it all the way up on mine. I bought my stuff at lowes as well
Old Feb 27, 2009 | 12:19 PM
Okay, thanks, I'll give it another try.
Old Feb 27, 2009 | 05:06 PM
Veteran: Army
white or black don't matter, if you read the article they put on f150.net, it shows the 2 ft piece that gets cut down and pics of trucks using both black and white pipe and there is no performance or appearance difference
Old Feb 27, 2009 | 05:18 PM
lanemeyer's Avatar
Some areas of the country dont have the black abs pipe due to building codes. That is what I found in my neck of the woods. I had to use white, I lightly sanded it and painted it black, now it blends right in.
Old Feb 27, 2009 | 05:20 PM
The King's Avatar
Did any of you find much of a difference in your trucks after the Gotts intake mod ?
Old Feb 27, 2009 | 05:25 PM
Veteran: Army
it ran better than it did with the K&N intake (and at that time the truck was full bolt on and had upgraded injectors)
Old Feb 28, 2009 | 01:18 AM
I just read this mod WON'T work on my 2007???? Have the 5.4
Old Feb 28, 2009 | 05:58 AM
Veteran: Army
I just read this mod WON'T work on my 2007???? Has the 5.4
jackandjanet worked out a mod for the 3 valve 5.4's but as we have described the "gotts" mod for the 2 valve engines it will not work the same way for your 3 valve, talk to jackandjanet and see how he modified his 3 valve intake tract
Old Feb 28, 2009 | 07:31 AM
fitz888's Avatar
I did it to my 08 it will work all you need is pvc use the stock rubber flex piece.The earlier gotts mod for the 2v is totaly different than the newer trucks.
Old Feb 28, 2009 | 10:53 AM
Okay got it, thanks guys. I hate the idea of using white PVC pipe. I think it'll just look wrong. Any pics so I can get an idea? You all know if it can be painted black or who might carry black PVC?
