No muffler
Old Feb 2, 2009 | 10:18 AM
Red301's Avatar
No muffler
i want to take my muffler off and strait pipe out the side, but after doing some research i'm hearing that this might be a bad idea.
is it true i will lose bottom end? and how much? i read about exhaust scavenging issues and such but i just want to be sure before i do it. the truck has four cats and i would imagine that must restrict the flow some what, will they do the job alone, or should i keep the muffler.......i have a cherry bomb vortex on right now
I really wish to know the right answer, so if your assuming, need not apply
Old Feb 2, 2009 | 11:47 AM
It wont be terrible, but performance is always better with a muffler. The velocity from the muffler to back at the cats keeps at a good pressure, no muffler stops that from happening, which therefore fools with your low end energy.
hi-flow cats help increase the flow with pressure, the rear converters are what kill the low end. Mine got better after I pulled the rear cats out, i can screech when i take off WOT now.
Old Feb 2, 2009 | 05:25 PM
Red301's Avatar
cool, thanks bro, went ahead and did it, and to tell you truth i noticed no lag at all, she cruises a bit better actually, just went a smaller diameter pipe to keep it from being too loud, it actually sounds not too bad!
Old Feb 2, 2009 | 05:44 PM
4wd150's Avatar
did you do a y-pipe to have duals out the back or just a single pipe? hows it sound?
Old Feb 3, 2009 | 03:25 AM
Fifty150's Avatar
Not sure if I like the idea of no back-pressure & smaller, more restrictive pipe.
Old Feb 3, 2009 | 04:32 AM
azmidget91's Avatar
i have a total of $22 into my exhaust, i used the stock piping and a chrome tip from autozone.....
i gained power....i did the same setup on alomars truck and he will agree.....
http://i69.photobucket.com/player.sw...0/IMGP0141.flv
windows down
http://i69.photobucket.com/player.sw...608_234800.flv
alomars truck
http://i99.photobucket.com/player.sw...raightpipe.flv
Old Feb 3, 2009 | 06:01 AM
JNC995's Avatar
Red, got any sound clips?
Old Feb 3, 2009 | 09:03 AM
Red301's Avatar
ok feller, i went ahead and did it, i had a 2 1/2 cherry bomb vortex, and i chopped the mo fo off, and stuck a 2 1/2 out the side infront of the right side wheel, i really like the sound.........i used a male coupling to connect the new one in to to restrict the sound, it made a bid difference from a female coupling, and a 3 1/2 inch stainless tip. its great...i like it, i and swear not a word of a lie, i gained power, some, may argue but i'm not gunna lie. when your cruising, its not loud at all....and i will try and get some sound clip for you boys, it doesn't crackle to much.......but its nascar-ish foresure.. i like loud, so some will argue......
Old Feb 3, 2009 | 10:26 AM
06hdfxst's Avatar
I took the muffler out of my '06 5.4 and ran a Y pipe using 2.5" duals with 4" tips and my almost has a classic sound with a slight gain in power.
Old Feb 3, 2009 | 11:01 AM
MudTerrain's Avatar
Backpressure is the enemy on every motor but a 2-stroke. Going with the smaller diameter pipe helped keep his exhaust gas velocities high.
Old Feb 3, 2009 | 04:53 PM
4wd150's Avatar
got a clip of how it sounds?
Old Feb 3, 2009 | 05:35 PM
bigdog87's Avatar
I have true duals 2.5" pipe. No mufflers, lost backpressure and economy(.5mpg) but worth it IMO. It' sounds amazing.
