Rear Cats removed
Old Jan 27, 2009 | 07:14 PM
JohnWade150's Avatar
Thumbs up Rear Cats removed
very very very loud but am wondering if i need to put a x pipe or something in it i have been hearing about loosing back pressure or what not somebody help me out(darren) on what i need to stick back there.
ill try and get a video sometime later on.
Old Jan 28, 2009 | 09:46 AM
An X pipe would be a pretty good choice. It wont kill all of your sound, only a small margin of it, it will due away with all low end rasp ( you'll still have it in WOT and high rpm ) and you will still shake the pavement with loudness, just with a properly balanced system. Since the left bank is longer and needs to be guided over to the passenger side ( original Y pipe ) its longer, and not as strong as the passenger bank is, the X pipe levels that flow out and is healthy for low end power.
Old Jan 28, 2009 | 03:49 PM
Yea thats what I plan on doing and I think I can pick up a x pipe for pretty cheap at one of the shops in town. I just want to make sure its alright if I keep them out and run like i am now.
Old Jan 29, 2009 | 01:44 PM
Yeah your not hurting anything, you'll just have some better low end with an X pipe.
Old Jan 29, 2009 | 04:28 PM
2004Triton5.4's Avatar
It sound's like you have the same exhaust setup as me. I also installed an X-pipe on my truck but removed it after a couple month's cause it didn't add any power but quieted my truck down too much. If your interested in an X-pipe i'll sell you mine for cheap. It has 2.5" inlet's and outlet's and does not have any rust.
Old Jan 29, 2009 | 05:32 PM
how much? And what are you running now? just straight without the rear cats or do you have flows or anything back there?
Old Jan 29, 2009 | 07:05 PM
I'm just running straight's right now. I plan on buying an 11" maggie and running my exhaust lightning style. I'll sell the x-pipe for $25 w/o shipping. I can't ship to canada.
Old Jan 30, 2009 | 12:07 AM
i am going to check at the muffler shop in the next couple of days cause i think he said he had one for 20 but if not i will take you up on that deal
Old Jan 30, 2009 | 12:14 AM
Downey's Avatar
how can you pass emissions with out the cats?
Old Jan 30, 2009 | 01:37 AM
You cant, thats why when you have emissions its best to not modify your cats at all.
Old Jan 30, 2009 | 08:52 PM
Yea they probably do have one cheaper mine is a magnaflow x-pipe that's why it was higher.
Old Jan 30, 2009 | 10:33 PM
1lohauler's Avatar
do you have any problems with your check engine light comming on? I know when mine comes on due to o2s failing I wont have any power when I push the gas to the floor
Old Jan 31, 2009 | 12:44 AM
Rear converter deletes on 2004 & 2005 trucks do not trigger CEL lights due to the rear sensors do not monitor the rear cats, they are infront of them, therefore monitoring the pre-cats only.
Old Jan 31, 2009 | 04:23 PM
1lohauler's Avatar
where would I buy the rear converter deletes mine is an 04 extended cab and thanks for the info
Old Jan 31, 2009 | 06:47 PM
You need to do it yourself. Its not legal so you wont find a kit. Check out my experience.
https://www.f150online.com/forums/ex...rear-cats.html
