Exhaust Leak
Old Jan 7, 2009 | 12:00 AM
jbracket's Avatar
Exhaust Leak
Lets see, 98 f150 ext cab 4x4 4.6L 137K and on the passenger side I had a leak from the flange. Well I tighted it up, and luckly I didn't break any studs. I also noticed that on the driver side I have a leak at the manifolds because one of the bolts broke that go into the engine. I was wondering if I can put anything on it to quiet the noise down, or something I can do as a cheap repair instead of paying someone to fix it. And also, if I leave it as be, will it be ok, or could it get worse?
Old Jan 7, 2009 | 03:34 AM
Best to get any exhaust leaks fixed asap because they will only get worse.
Old Jan 7, 2009 | 12:45 PM
jbracket's Avatar
Well it's only one bolt that broke off of the manifold, so I can't see how all the other bolts would break off, but it's gonna be an expensive job to fix, and I don't have that kind of money right now.
Old Jan 7, 2009 | 05:49 PM
Cheap bolts can be a troublesome fix in the distant future, bummer that Ford didn't use better ones. Your not the only one who has gone through this.
Old Jan 14, 2009 | 09:50 PM
jbracket's Avatar
Well as long as it will last me till may, I plan on buying a diesel anyways, so.... but thanks for your help
