Gott's intake questions
Old Nov 10, 2008 | 07:31 PM
weswhall's Avatar
I need some help. I'm doing the intake tomorrow and I got the materials today. I just have a couple questions.
I need to know how long of a section of PVC to cut. I've read that somewhere between 4 and 5 inches, but is there an exact length?
Also, how far do I need to sand down on the pvc. I mean, I know how much I need to sand is just enough so that it goes into the fenderwall, but I mean how far does it need to reach inside to the fenderwall? Maybe like 1.5 inches?
I appreciate the help and I can't wait to see the results.
Old Nov 10, 2008 | 10:32 PM
mblouir's Avatar
Don't know if you've seen this but hopefully it helps. It says a piece between 4 and 5 inches that sticks at least 2" into the fenderwall.
Gotts Intake
Old Nov 10, 2008 | 10:43 PM
31 YNOT's Avatar
i ground mine down just so it stays in place in the fender, it doest really even go into the fender, just as long as thats where it pulls the air from
Old Nov 10, 2008 | 10:50 PM
polevaulter95's Avatar
best way for you to decided exactly how much you need to cut and sand is trial and error while your working on your truck. good luck its pretty darn easy, and quiet amazing how small of a hole it originally draws thru compaired to the pvc pipe.
Old Nov 11, 2008 | 01:33 AM
Veteran: Army
like they said, however a 4-5 inch piece will give you more room for error
Old Nov 11, 2008 | 07:35 AM
weswhall's Avatar
Thanks guys... I just started working on the sanding.
Old Nov 11, 2008 | 08:02 AM
Veteran: Army
can you post a picture of the pipe before you install it? so others can see the different examples that work
Old Nov 11, 2008 | 09:08 AM
I used a rubber coupler designed for PVC pipe joining. Has worked pretty well, and was just the right length for my truck.
Plus it was already black to match the rest of the engine bay
Old Nov 11, 2008 | 10:58 AM
weswhall's Avatar
I'm working on it. Sanding PVC pipe ain't no joke. I'll post a picture of the pipe and process later, although I've never posted a picture on here, so I could need some help with that too haha. Thanks again guys.
Old Nov 11, 2008 | 05:00 PM
weswhall's Avatar
Alright guys... I need to know how to post pictures
I know you click the "Insert Image" button, but my pictures don't have URL's. Thanks.
Old Nov 11, 2008 | 05:18 PM
mblouir's Avatar
What I do is upload them to a photobucket account and post their url links. You can also upload to your album here and from your album there should be an option to add a picture to a thread.
Old Nov 11, 2008 | 05:44 PM
weswhall's Avatar
Gott Intake Install
After sanding down a 4.5" long piece of 3" PVC pipe, I put it through to the fenderwell. I made sure that I did a lot of trial and error, so that it fit as snug as possible.
I put the 3" coupler on the PVC and tightened it down.
Put the air filter drum on the coupler and tightened it down.
Put the K&N filter back in and tightened it all down.
Old Nov 11, 2008 | 05:49 PM
weswhall's Avatar
Just for reference
Here is my truck
Old Nov 11, 2008 | 07:32 PM
mblouir's Avatar
Here is my truck
Truck looks great for an '01, man. Love the mix of color on it.
Old Nov 11, 2008 | 07:41 PM
weswhall's Avatar
i appreciate it man. She's got a few years on her and just tipped 140k, but I keep her clean. You might appreciate this one.
