OBX header questions
Old Oct 30, 2008 | 08:48 PM
FORDFAN2007's Avatar
From what i see and hear, the OBX LT headers with y pipe, does not come with cats, only resonators, will that not make a check enging light come?
Do you need a special tune to run any long tune headers?
Do you need to buy some extension wiring for the oxtgen sensors to reach?
Old Oct 30, 2008 | 09:19 PM
f150fella08's Avatar
check engine light? yes im pretty sure it will come on, ever seen inside a resonator?? looks like a tiny glasspack so i would assume it would come on
special tune? wouldnt think so, what years the truck
extensions? yes i believe you will have to buy extensions
Old Oct 30, 2008 | 09:29 PM
Blown F-150's Avatar
You might not get the CEL right away, but it will come on eventually. A tune is recommended to get the most out of the LT's and it will also help offset some of the low-end torque loss.
I had to get extenders, for my front o2's but the back ones were fine. You should replace the resonators with High-Flow Cats for best results. I am happy with my set up, and you can still get any stock compatible cat-back to bolt up.
Old Oct 30, 2008 | 10:28 PM
See this is where my frustation sets in , I would have to do so many things to get long tubes right, worry about check engine lights, find a shop that would be willing to do the work so on and so on
Seems getting shorties is just a better option. Cheaper to buy , easire to have installed, no check engine lights.
But on here over and over, people say no shorties, there has to be some performance benefits of shorties, of course not like LT, but some performce, quicker throttle? better sound?
Old Oct 30, 2008 | 10:30 PM
Its a 98 4.6 by the way, no special tune, just a regular Edge,
Old Oct 31, 2008 | 08:24 AM
shorties dont do anything maybe sound benefits maybe quicker throttle but besides that nothin
Old Oct 31, 2008 | 11:48 AM
Klitch's Avatar
ebay has mil eliminators (probably for mustangs) that should be placed in the rear o2 sensors, that aughta keep you from getting the red flag.
Old Oct 31, 2008 | 11:56 AM
jbrew's Avatar
Or here - http://www.rpmoutlet.com/gmo2s.htm
Old Oct 31, 2008 | 12:20 PM
So do I get extensions for the front o2 sensors, than also buy the simulators for the rear?
Old Oct 31, 2008 | 12:26 PM
If you don't want to run cats then yes get the eliminators. You will need extensions for the fronts, if your good with a solder gun, people on here have soldered their own extensions. For the rears you could also try Gotts non-fouler mod, seems to have been working well for him.
You will see a improvement with LT's, but I highly doubt you will notice anything with shorty's.
Old Oct 31, 2008 | 01:36 PM
I would still like to run cats, although I dont think all four are nessesary
Old Oct 31, 2008 | 03:18 PM
jbrew's Avatar
I would, unless you plan on tuning for just resonators and you don't have to pass emissions testing in your state.
Old Oct 31, 2008 | 04:11 PM
I dont have emissions where I live, so I think just the two rear cats will be fine.
Old Oct 31, 2008 | 05:40 PM
If you remove all four of your cats and and purchase to High-flows, you can take you OEM cats to the scrap yard and will probably get more for them then what you'd pay for the High-flows.
