Longtube header installation price
Old Oct 25, 2008 | 05:58 PM
doubleplayer's Avatar
So I was qouted 300 dollars for installation of longtubes on my truck, (2002 5.4). Now I have two questions, is this a good price? and which longtubes are the best? Thanks alot.
Old Oct 25, 2008 | 08:15 PM
The fact that you found a place that would install them is incredible. Lucky. Sounds decent. You and a couple friends and a 24 pack could do it cheaper though. Dynatech is the best.
Old Oct 26, 2008 | 08:56 AM
minimonster17's Avatar
install is something of a PITA, so yeah, that's a decent price. HOWEVER, you will need further exhaust work upon LT installation, and that may cost you ~$200. the cats have to be moved back to compensate for the extra length of the headers, and o2 sensors have to be rebunged. you'll need o2 extension wires as well, or you'll have to extend the lines yourself, manually. i think you can do it yourself, cut off your exhaust, and drive to the muffler man open headers, and have him fix your exhaust.
do a thread search for threads by user txoutlaw. he did a write-up on dynatech header install on an L, but mostly everything will still apply to a N/A 5.4.
Old Oct 26, 2008 | 05:31 PM
I looked up the dynatechs and they are a little more then I was hoping for, are there any for around $700?? And i noticed that I couldnt find any for a non lighting or HD. Will they still fit?
Old Oct 26, 2008 | 07:41 PM
jbrew's Avatar
Yea. They will fit.
Dynomax LTs can be had cheaper, OBX cheaper than that. Pace Setters the cheapest.
Old Oct 28, 2008 | 04:45 PM
01Roush's Avatar
I bought OBX for around $450, quality was excellent. Installation was a breeze, both slid right in place. Only thing that really slowed it down was installing stage 8 locking bolts, takes a while to get them in but not that bad. I replaced the OBX resonators with Maggie bullet cats and used a 'Y' to connect to my 3" single exhaust. I have around $850 into it altogether and picked up around 25/40 at the wheels.
Old Oct 29, 2008 | 03:55 AM
Klitch's Avatar
lol hey roush, yeah the stage8's are hard to get in, have you looked at how fun it will be to remove them? i know i have!
Old Oct 29, 2008 | 08:25 AM
01Roush's Avatar
Try this on for fun..... A few days after install I had a bad exhaust leak on the driver's side and assumed the gasket was leaking since I re-used the stock gaskets. I figured I'd make sure all the bolts were tight so after getting all the clips off and about the time I finished torquing the last one I glanced up to see the egr nut sitting there loose.... I had threaded it on by hand but forgotten to go back and tighten it, and took all the clips off on that side for nothing.....
To make it even better one of the clips sprung off into suspension/frame neverneverland and couldn't be found so I'm running without one on that side...
Old Oct 29, 2008 | 08:56 AM
jbrew's Avatar
Oh that never happens
Couldn't find mine for awhile after doing something else, smart. I ran with both sides off until it rained.
Old Oct 29, 2008 | 01:40 PM
Klitch's Avatar
lol, yeah i about cried when i heard an exhaust leak, i did the same thing and forgot to tighten the EGR down. left it loose to fit it to the plenum then though nothing of it afterwards. lol
