DI/SO question
DI/SO question
Someday I plan on a whole new exhaust setup, but for now Im in the planning stages.
Ive had a few setup running through my head and have one Im curious about.
Right now I have a Magnaflow SI/DO muffler setup on my pickup, just from the stock Y pipe back. And I know you can reverse a Maggy muffler so I thought of this...
Long tubes will be going on, most likely Maggy HiFlow Cats, and from there back I was thinking of running the left and righ side into the dual part of the muffler, with a single pipe exiting.
Maybe just because its more complicated to fab up, but why dont I seem to see many DI/SO setups. Is there a reason (power wise) or anything. Seems to me like the DI/SO muffler would just act as a Y pipe to a single exhaust system, no?
Im just curious if there is a good reason I dont see many setups like this or not. Im no exhaust expert so I wondered if maybe this type of setup just didnt make good power or something...
Looking for most power first, with good sound a close second.
Anyone have any insight on this? Thanks...
To add....Im just in the thinking up ideas/planning stage right now since Im not sure when I will get around to doing this.
I wouldnt mind using the muffler I have now since, well, I already have it. If there is a *perfect* setup that works for the most power though, that involves ditching the muffler I have now though, let me hear about it too...
DI/SO isn't too popular because a majority of people with dual pipes would rather have dual tips.
LTs with 2.5" dual pipes going into a dual 2.5" to 3" out muffler would be a great setup for torque. GMs HD trucks from 2001 - 2006 were similar to this, and they maintain very good torque numbers.
Kinda figured that too...if someone is going to do a custom exhaust job they want duals.
I was thinking 2.5s in and 3 inch single out also...then I remembered that my muffler's single side is 2.5" also. Im not sure if it would still be benificial to bump up to a 3 inch pipe right after the muffler since its was already necked down to 2.5, or if that little bit of single 2.5 right out of the muffler would even make a big difference if I bumped it up to 3" afterwards.
And since Magnaflow mufflers are straight throughs with internal Ys and Xs, you can just flip you SI/DO around ( that is if the single is 3" )
