anyone s&b with bodylift?
Old Oct 9, 2008 | 06:28 AM
ColonelBlue's Avatar
Question anyone s&b with bodylift?
does anyone have a bl with a s&b or know of some one.cause i am looking into adding a bl and i already have the s&b would there be problems
Old Oct 9, 2008 | 03:47 PM
john1102's Avatar
What kind of problems are you thinking about? I dont see why there would be a problem
Old Oct 9, 2008 | 09:06 PM
Arca_ex's Avatar
Well the plate that it's attached to would raise up with the body wouldn't it? I think you might have some problems there but wait for somebody to chime in on that...
Old Oct 10, 2008 | 10:32 PM
I have no direct remedy, but you cant bodylift with the intake, theres a needed modification to mate it up.
Old Oct 10, 2008 | 10:43 PM
MikeSwt's Avatar
Yeah the box the S&B has is bolted down to the body of the truck. I looked at it as I was installing mine because I was gonna put a bodylift - Ive since decided on the Rancho lift instead. I think it would fit fine - Worse comes to worse you could add small section of tubing to reach the box once its mounted.
Old Oct 11, 2008 | 12:19 AM
i already have a rancho but was looking to go higher
Old Oct 12, 2008 | 07:53 PM
06yz250f's Avatar
you could do a 2" AS spacer and AAL or larger block in the rear. can you post a pic of how it mounts. does it kind of go by where the stock inlet goes from the wheel well? or is it farther in?
Old Oct 13, 2008 | 02:18 PM
yeah it goes in on the same spot as the stock went before. i thought about the spacer deal to but im purchasing a tuner hopefully this week so the lift will be later.....
