Sock exhaust pipe diameter??
Hey guys. I've been wanting an inexpensive way to make my exhaust sound half way between stock and loud
It seems that a single Magnaflow muffler mated to the stock pipes will do just that. I'm thinking 5x8x14 or 5x8x18.
Does anyone know the OEM pipe diameter for the Inlet/Outlet?
Yall are much appreciated!!
Matt N
Matt N
why dont you go out side and measure it, but i belive it is 2 1/4 or 2 1/2, if you really want cheap cut your stock muffler out and put in a peice of pipe in it place but our mufflers look like rv mufflers!
i would definately check out the 14" or maybe even the 11". maggies are a lot quieter than anything else. i went with the 4x9x14, and now im wishing i went with a 11" or a si/do instead. at first, you are all happy because it sounds awesome, but then you are upset because its not loud enough. mine is the part no: 11226. its a si/so 14". check out the sig for my vid. $63 shipped from performancepeddler.com!
