Serious mpg loss?! wtf?
Old Sep 17, 2008 | 10:42 PM
Arca_ex's Avatar
Originally Posted by 2004BlueXLT
Anyone else run into this problem?
No...
Old Sep 18, 2008 | 08:56 AM
BlessedF150's Avatar
I just got throught installing a K&N CAI in my '05 5.4 and lost about 2 mpg on the highway. I also followed the direction to the T and made sure the mass air sensor wasn't touched at all. I don't get it. I made sure that I tested the mileage at the same speed, windows down and no a/c, etc just to make sure that all the variables stayed the same. I don't have an exhaust yet, but that still shouldn't have a negative effect on my mileage.
Old Sep 18, 2008 | 10:13 AM
2004BlueXLT's Avatar
See, it just really doesn't make sense to me that it reduces your mileage...I mean, I did a few other minor things to help the mpg's a little bit (like exhaust, constant tire pressure monitoring, etc...) and everything I've done has helped in one way or another except for the CAI.
Now I'm finally breaking down and considering a custom tune...I just have a hard time dropping 400 for a gryphon or something equivalent unless it is almost guarateed to have positive effects without being detrimental to the health and well-being of the vehicle...
Old Sep 18, 2008 | 12:45 PM
Did you reset your PCM after the install?
Old Sep 18, 2008 | 01:26 PM
dixiedesign's Avatar
Odd. Gained MPG when I installed mine.
Old Sep 18, 2008 | 02:00 PM
PCM...? Remember...I'm no expert, thats why I'm here
How would a guy go about resetting his "PCM"?
Old Sep 18, 2008 | 04:58 PM
4.6 Punisher's Avatar
I think that their is a problem with 5.4 3 valves running lean after installing an aftermarket CAI. It doesn't happen to 100% of all 5.4's but a good majority do end up with this symptom. This will include less MPG's and possibly a check engine light. The only way to cure it is to get a custom tune, Edge, Gryphon, etc. It'll end up costing you around $400-$500, depending on the brand, and yes they do have multiple settings.
Old Sep 18, 2008 | 08:33 PM
Keeks's Avatar
I installed the S&B and gained ~1 mpg. I also have a Roush cat back system and no tunes.
Old Sep 18, 2008 | 09:02 PM
This is getting to be ever more ambiguous...
So it boils down to being luck of the draw with CAI's causing lean conditions? Mine didn't ever trigger a check engine light or anything...
I used to be skeptical about custom tunes, but now I'm doing the research. I've emailed PHP a few times asking questions and what not...I think as soon as I can come up with 500 bucks I'm gonna order one with the 87 economy (?) tune and another one to tear the streets up with every once in a while
Anyone have suggestions on what tunes to get from PHP?
Old Sep 18, 2008 | 09:06 PM
skyhikr's Avatar
I think..
Ya I do have a cat back SIDO exhaust job. And, yes, I did reset the battery like the instructions said. I did look at the MAF sensor when I was putting the factory intake back on and it wasn't oily or anything.
About a custom tune...how much would a good one cost me? I'm just a college kid, dropping 270 bucks for that intake was about all I could handle for a while...luckily the manufacturer was cool enough to refund the money. I'm not looking for gobs of power or anything...just a few extra mpg's, thats all. But if its possible, could a guy get one with a few different user changeable settings with different parameters to adjust for fuel mileage, power, etc...? It would be kinda neat if I could just push a button and go from getting 23 mpg to shredding my tires off the wheels (just to blow the cobwebs out, of course )
I appreciate all of your feedback! Thanks...
I think it was the Maf. I have an AFE intake and I picked up about 1 mpg. AFTER the first 500 miles with the intake on. I pulled the MAF and cleaned it even though it did not look lke it needed it. Wow what a difference! I clean it every 5,000 miles or so and it really helps. I am going to go with a AFE dry filter in a few more miles. I Think the oil on the CAI filters seems to cause a bit of a problem and I hope the dry filter will help.
I get 19-21 mpg on the freeway running at 64 mpg in the flats unloaded and it might be more but most times I am no going very far without my trailer to really tell. 12.5 mpg with my trailer with no hills, 11 thru the mountains.
Old Sep 18, 2008 | 09:08 PM
Disconnecting the battery (for some ammount of time, can't remember how long) will reset the PCM, the powertrain control module. Maybe since you're getting more air into the engine without resetting the PCM you're engine isn't compensating properly. Just a thought.
Guys feel free to correct me if I'm wrong on this.
Old Sep 18, 2008 | 11:57 PM
Good lord...I'm right at the intersection of confused and don't what to do.
I've heard all sorts of talk about how a CAI with no tune will make you run lean, and then have people say that they had absolutely no trouble with them with no tune. Then I get one and lose mileage, then hear all of you saying that you gained mileage (even those of you with no tune). This is nuts...my head won't stop spinning
Old Sep 19, 2008 | 12:05 PM
It's really hit or miss. The 4.6's don't have this issue, just the 04+ 5.4 3 valves. If you are planning on putting a CAI on your 5.4 truck, make sure you have enough money for the programmer just in case the performance suffers.
Old Sep 19, 2008 | 01:28 PM
ThumperMX113's Avatar
It's not just the 5.4 3V, it's all 3V motors, which includes the 4.6 3V.
Old Sep 19, 2008 | 01:39 PM
I'm just taking a shot in the dark here...3 valve means 2 intake valves and one exhaust valve, correct?
If so, do the issues arise from breathing in more air than the engine and exhale? Sorry if thats a dumb question...like I've stated many times before: I'm not a mechanic
To go further, would the problem be solved if it were, say, a 32V (4 valves per cylinder)?
