towing exhaust
towing exhaust
i'm just wondering what would be the best exhaust set up for towing, long tubes into true duals with an xpipe or more like a dynatech long tube system and then to a nice magnaflow cat back? again its for towing so i want soild power but not killer noise
long tubes to start, (dynatech are good) replace the 4 factory cats with magnaflow hi flows, then a X pipe to regain torque, then i believe magnaflow will be the best thing, bassani, or borla
the longer muffler the quieter the sound, bassani and borla will give you the most "towing power" but their really really expensive, magnaflow makes a 24" muffler i do believe, and if you run the pipes out of the back behind the tires you shouldnt hear much inside if any,
You cant have true duals & a cat-back at the same time. I would skip out on the LTs, and just get hi-flow cats and a 14" si/do Magnafow with tips of your choice.
Honestly... Stock.
Unless you're doing a completely new exhaust system (basically from the manifolds back) it's hard to beat the low and mid range torque of the stock exhaust.
If you wanted a new system --- long tube headers (solid 30hp/30tq gain), highflow cats, X-pipe as close to the cats as possible, 24" Magnaflows (to keep the sound down), and pipes out the back, all mandrel bent of course.
Honestly... Stock.
Make sure to have your tips exit to the side, not straight out the back. Otherwise you'll get to listen to the sound of your truck echoing off your trailer the whole time.
thanks for all the posts, i definately want the tips tucked up nice and tight and out the sides, i do plan to do the whole system starting with long tubes, into hi flow cats xpipe and 24in maggies, any suggestions on headers i thought dynatech but i'm sure there are others too
