Adding QAEM Brute Force, removing PoweRaid throttle body spacer
Old Jul 24, 2008 | 08:56 AM
fnckr's Avatar
Adding AEM Brute Force, removing PoweRaid throttle body spacer
The previous owner installed a Poweraid TBS and I want to remove it. In August, I'll be adding a CAI, probably the AEM unit.
So, if I remove the TBS do I need to buy four new stock bolts for the throttle body? Or, will the longer ones from the TBS still work with the TBS removed?
Does the AEM unit affect those bolts at all?
Old Jul 24, 2008 | 11:03 AM
Shortbox54's Avatar
my guess would be that it doesnt even use them, try downloading the directions online, and look at the final picture?
joshmac4.6's Avatar
you will have to buy new bolts, the ones for the TBS are a 1" or so longer.
Old Jul 25, 2008 | 08:57 AM
fnckr's Avatar
Thanks! Guess I'll be making a trip to the dealer for the bolts. Unless, does anyone know what size they are? Also, will I need any gaskets?
Old Jul 26, 2008 | 04:08 PM
wakborder76's Avatar
when taking out the throttle body you'll need new bolts for the stock intake but the brute force doesnt use the 4 mounts that hold the air box in place. It only uses the one bolt holding the intake tube in place.
