Magnaflow true duals... any risk of... ???
I'm planning to get Magnaflow true duals put on my truck tomorrow morning.
Is there any risk of anything stupid... Like check engine lights coming on later ???
The reason I ask, is that I read the post where the guy put on a CAI, then had check engine codes coming on. I know this is because of the leaning aspect of a CAI. Maybe he can get a tuner to correct for that, but I don't want open that "can of worms". So no CAI for me either.
I was planning on the Magnaflow TD's and probably never another single thing, as far as performance goes (already will have more power than I will ever need).
It would just be really lame if my first and only performance mod, caused any issues, like a 'check engine light' or anything else, that I haven't thought of....
Anybody ever have, or hear of somebody else having any kind of problems from aftermarket mufflers ?
Thanks,
Fish
Thanks,
Fish
Are you doing true duals, or one exhaust pipe that splits into 2 pipes the exit the truck? I didn't think Magnaflow made a true dual setup, or are you getting custom piping? Just be sure your O2 sensors don't get cut out for some odd reason and you should be just fine.
I've got true duals on mine with 2 SISO flowmasters and never had any issues. Since getting the exhaust I've also put on a new intake and got custom tunes written to take care of the A/F ratios.
- NCSU
- NCSU
Hey NCSU....
I'm going down to discuss the options with my muffler pro buddy, this morning. Put it this way, if I couldn't have "true duals" from Magnaflow, I might just switch brands.
I had actually heard that true duals were an easy thing to do on an F150, as they already have twin cats, and instead of bringing the pipes together in a 'Y', and then into the factory single exhaust, you would simply come off of each individual cat, and go straight into a seperate exhaust on both sides... Then maybe throw in an 'H' or 'X' pipe, and be done with it...... No ?
Hmmm,
I'll find out this morning.
Peace,
Fish
PS, You said
Yea'.... You and everybody else "except" Fish Chris. IMPO, tuners are a bottomless pit full of potential issues.
It's a piece of machinery. Already enough potential for issues, as it is !
PS, I saw your wheels on another local vehicle yesterday.... and they looked bad-***.... But your truck looks way better :-)
Hmmm,
Peace,
Fish
The difference between what you described and what I've got is the running of the dual pipes. Both pipes need to run down the passenger side as the fuel tank gets in the way of the drivers side. Other than that, you've got it!
Ideally, you'd take your truck to someone like that and let them create a tune while your truck is on the dyno. That way everything can be seen in real time, and everything can be fine tuned. I haven't had any problems with mine and I wouldn't drive an 04-08 without one!
They're a PITA to keep clean though!- NCSU
