takin out cats
Old May 29, 2008 | 10:14 AM
f150 rider's Avatar
Buy the Hi-Flow cats, have the 4 stock cats removed and have them two installed.
well said this is exactly what I`m having done to my truck right now, here is a link for homemade mil eliminators and they work too, it cost less than $10 for all the parts from radioshack just solder it together and you will have no CEL, I did it to mine, and to see if it would work I took both of the rear O2 sensors out of the pipe and and started the truck and no CEL!!!
this is the easiest way to solder it up
http://www.mustangforums.com/upfiles...B74B899C9A.jpg
Here is the page that has all the part#s you`ll need, just hit previous and next to see dif. pics
http://cobrasvt.homestead.com/files/.../mil_close.htm
Old Jun 1, 2008 | 02:19 AM
DSC05's Avatar
Originally Posted by Andy-jr.
Yes, I just bought the high flows and I only have a SI/DO magnaflow muffler. the part #'s for what I have are 94306 for the cats and 12198 for the muffler
Thanks....Did you remove all 4 cats or just the rear 2?
Old Jun 1, 2008 | 09:34 AM
f150 rider's Avatar
I removed all 4 and replaced those with 2 highflow cats, its sounds so much better and I can tell a little better throttle response
Old Jun 4, 2008 | 02:58 AM
DSC05's Avatar
What size pipe are you running. Ive been told to go with 2.25 for true dual and 2.5 for a set up like yours. Just curiouse what your running.
Old Jun 4, 2008 | 07:35 PM
Andy-jr.'s Avatar
I removed all four cats
I have 2.5" pipe
Old Jun 4, 2008 | 11:33 PM
Red-04-F150's Avatar
so to clarify. if i remove just the 2 rear cats the truck will still run fine and the check engine light won't come on? If i go with high flows the 02 sensors can still plug into them right?
Old Jun 5, 2008 | 05:44 PM
tech-doc's Avatar
YES
