[sound clips] Flowmaster Super 44 4.6L Single In Single Out
Flowmaster Super 44 Freshly installed, i used the stock tailpipe and i am not sure if i am going to put a tip on yet or not. but here is what i have so far for sound clips
http://youtube.com/watch?v=oK_V7j8DsOg
http://youtube.com/watch?v=v6aTkHz1pwQ
http://youtube.com/watch?v=XSIqRpIYUb0
all of these were taken about 9:30 this morning, after i break them in a bit i will post another video to see if it got any louder, i can tell the more i drive it is getting a bit better.
Sounds great! Not too loud inside. Congrats.
& I would definitely add a tip, not just for looks, but a tip can give it a deeper tone and echo it better. If its all 2.5" I would suggest a 3.5" outlet tip.
the muffler is actualy 3 inches, and the pipe comming to the outlet i had a reducer put on to make it 2.5 so it could run the stock tail pipe, i am going to eventually change it out and get true dual, and put 3 inch all the way around. but for now this will due.
Well 3" true duals on a gas V8 isn't really good unless your block is 350ci+. My Silverado has 3" true duals with the Super 44s, Magnaflow cats, & a H pipe & it runs perfect, no loss or gain. Its got a 6.0L 364 gas V8 in it though. Running 3" true duals on a 281ci 4.6 would really hurt your performance. If you plan for true duals, keep the pipe size no larger than 2.5" max, I would actually have 2.25" duals for a 4.6 though. These trucks really rely on the backpressure and bigger pipe loses it all, and loses your torque and economy.
